Ecco che anche Stanton si butta nella mischia della console per DiJ ed al MusikMesse 2012 presenta la DJC.4, una console 2+2 deck che a differenza di molte concorrenti vanta un mixer VERO con ingressi Phono/Line ed uscite master bilanciate e sbilanciate, per usarla come mixer senza PC sarà ovviamente necessario alimentare la console a parte.
Il software allegato sarà VirtualDJ LE.
Features
4 channel (Dual-Stereo) 16bit/48kHz audio interface allowing comprehensive connection to your sound system
Included Virtual DJ LE software allows for 4-deck control, video mixing, effects, with plug and play functionality
2 or 4 channel control with deck shift functionality and browser loading, giving direct access to the controls you need fast
Long-life replaceable Cross fader with hardware fader curve knob allowing your custom cutting preference to be dialed in
Rugged metal chassis, designed to withstand years of use in the most rigorous environments
95 assignable MIDI controllers (63 buttons, 5 faders, 12 push encoders, 22 control dials, 2 touch-sensitive jog wheels) & shift function
DJC.4 Tech SpecificationsMixer
Analog inputs for turntables or CD players, with direct pass-through to software for DVS control
Each channel can be assigned to either 2 MIDI decks (A/C, B/D) or an analog input via toggle switch
User replaceable 100K cycle 45mm cross fader with adjustable curve
3-band EQ control w/ complete KILL plus gain per channel
VU meter LED for level monitoring
1-Balanced (1/4″ TRS) Microphone Inputs w/ separate volume & shared tone control
Player
2 touch-sensitive platters with adjustable sensitivity
Two long, high-resolution 14 bit pitch faders for precise matching
Two pitch bend buttons
Extensive loop & sample section includes 4 large CUE/LOOP trigger buttons on 2 banks
Full effect control with 4 encoders and buttons for instant control
Master Connections
Master Out: 1-pair TRS (1/4″ Balanced), 1-pair RCA (unbalanced)
Booth Out: 1-pair RCA (unbalanced)
Headphone Out: 1-TRS (1/4″ Stereo Balanced) 1-Mini Jack (1/8″ Stereo Balanced)
Input 1: 1-pair RCA (unbalanced) – phono/line switchable
Input 2: 1-pair RCA (unbalanced) – phono/line switchable
Aux Input: 1- 1/8″ Stereo Balanced
Mic: 1-TRS (1/4″ Balanced) each
USB: Type B
Power: 12V / 2.0A DC Input
General
Dimensions: 44 x 410 x 275 mm (H x W x D)
Weight: 7.0 kg
Includes Virtual DJ LE 4-Deck Edition CD with license, and discounted Virtual DJ Pro Upgrade
Features
Player
Master Connections
USB: Type B
General
Weight: 7.0 kg
Il prezzo al pubblico dovrebbe essere sui 400 Dollari ma non si sa ancora quando sarà in vendita.
Posted Mon 02 Apr 12 @ 3:55 am
