Kalispera kai apo mena, molis grafthka sto site (kai to forum).
Exw kai gw kapoies apories pou prokyptoun apo to syndyasmo mias Hercules dj console RMX (kyriws apo ayth pistevw) kai enos vdj 7.0.5 Pro
Ta parapanw einai syndedemena/egatesthmena s'ena tapeino pc turbo x (me enswmatwmenh soundcard) kai katalhgoun s'ena hi fi (!) enisxyth yamaha rx v 440rds kai dyo hxeia yamaha ns200. Hdh, me ayto to sthsimo exw valei aytogoal apo ta apodythria oson afora to exagomeno apotelesma, fantazomai!
Sygekrimena, h poiothta tou hxou einai kakisth paroti paizw mp3's sta 320 kai flacs, apoti parathrhsa h enswmatwmenh karta hxou ths hercules, exei rythmish gia asio kai wdm (allo mode ayto!). H asio exei sample rate, sample size kai asio buffer rate 44100 hz, 16 bit kai 10 ms antistoixa. Exei epishs kai pio "poiotikes" epiloges, opws 48000, 24 bit kai arketa alla buffer rates. To zoumi einai pws enw exw epileksei ta teleytaia (gia evnohtous logous), molis energopoihsw to vdj, aytomatws mou to gyrizei se leitourgia wdm h opoia den exei kammia parametro na rythmisw. Etsi, apolamvanw ton kakisto (se sygrish me ayto pou tha mporouse na apodwsei) hxo. E, tis rythmiseis tou vdj, pistevw pws tis exw kanei swstes, dld input none, output headphones kai sound card dj console rmx (asteri, sou lew!) Me mappers, options kai performances den exw asxolithei, mh ta kanw pio sk...a apoti hdh einai! Apoti eida to latency einai sto auto (epeidh paizei rolo to lew).
To deytero einai o thoryvos pou ekpempetai apo ta hxeia prin kan arxisw na mixarw, kai o opoios ksekinaei molis anoiksw to vdj. Isws exei na kanei me hlektrismo alla as mh vgazw aythaireta symperasmata.
Kleinw anaferontas thn "spasmwdikh" roh tou mixing, dld mia roh ths mousikhs pou moiazei na "kollaei sth lasph" kapoies fores, kyriws otan kanw tis allages...ti na pw, to pc exei 2 gb ram, afthono xwro sto hd kai ennoeitai pws den katevazw h kanw kati allo ekeinh th stigmh. Gia na synopsisw, pistevw pws prepei na kanw egatastash apo thn arxh kai na pragmatopoihsw tis swstes rythmiseis, opote oti mporeite na mou proteinete me logakia h kapoio link gia arxarious tha voithouse poly! Eyxaristw gia th filoxenia, συγνώμη gia to greeklish katevato kai elpizw na diaskedasate me thn perigrafh!
Posted Sat 10 Mar 12 @ 4:03 pm
Φιλικά:
1) Ξεκίνα να μας περιγράφεις ΑΚΡΙΒΩΣ την συνδεσμολογία σου.
2) Ενημέρωσε το προφίλ σου με τον σειριακό αριθμό της έκδοσης PRO που διαθέτεις.
3) Εάν δεν διαθέτεις την επίσημη έκδοση PRO (αλλά κάποια σπασμένη) κατέβασε την έκδοση HOME FREE και κάνε δοκιμές με αυτή την έκδοση. Οι σπασμένες εκδόσεις σαφώς και δεν υποστηρίζονται εδώ.
4) Την επόμενη φορά προσπάθησε να γράφεις με ελληνικά εκτός και αν υπάρχει κάποιος σοβαρός τεχνικός λόγος. Προσωπικά ακόμα και όταν μπαίνω στο forum απο το κινητό μου μπορώ να γράφω σε ελληνικά χωρίς κανένα πρόβλημα.
5) Για να χρησιμοποιήσεις ASIO drivers στις ρυθμίσεις πρέπει να επιλέξεις ASIO και όχι Hercules RMX
6) Υπάρχουν πολλοί λόγοι που δεν θα σου πρότεινα να χρησιμοποιήσεις κάτι διαφορετικό από 44.100Hz/16bit. To VirtualDj δεν είναι DAW.
Posted Mon 12 Mar 12 @ 1:45 am
Σ' ευχαριστώ για τις παρατηρήσεις σου.
Posted Mon 12 Mar 12 @ 2:14 pm
