Topic: Can a Moderator help me ?
Hello :
I need to download Vdj 2.1 , OR THE Last Vdj with i can write TAGS .
Thanks in advance .
Posted Fri 17 Feb 12 @ 10:58 pm
You can do it on 7, right-click the track and select File Info.
Id3 Tag export/import is supported, too.
I will try this tool . I don't want to do my cues , bpm's again and again .
Ok , I'm trying the tool ...but i'm thinking : what about tomorrow , when i set new cue points ?
I think it would be perfect to have this feature back (save tags )
The most important is to have all the Bpm's , I will save all my info into files with this Manager .
Thanks
If i read the files in another Pc , i see the songs as NOT ANALYZED without Lengh and Bitrate . :-(
OK, some explanation required here :)
The length, gain, bitrate etc. cannot be stored in the tag. They are kept exclusively in the Virtual DJ XML database file. BPM can be exported using the tool above however.
If you are moving songs from one PC to another you will need to copy the VDJ database file, however it assumes the songs on the second computer are all present and in the same file path. If both PC's have different music on them then you will have to reanalyse the file.
If you are using an external drive this is different, the VDJ database will sit on the root of the drive and it can be transferred easily from one PC to another.
Please let me know if you require any more info.
Keith
An example would be If you were to play a file from a flash drive and were to open that drive to view files later... you'd see that XML doc. Vdj tags every drive you use.
