Hi!,
I just bought VirtualDJ pro full to use it with the Numark N4 controller. It is going quite well on many aspects but for one... CUE. I Thought CUE was ment for that you can play one song on the speakers and start one song in your headphones with pressing the cue button... but it plays all together.
Is there some adjustable settings or driver to fix this problem, or do I not "get" dj-ing at all..?
I cant find the controller it says NS4 in the mappers settings.
Thanks,
Daniel Høifødt
Thanks,
Daniel Høifødt
Posted Wed 15 Feb 12 @ 2:53 pm
use these settings bud
sound setup:
- input: none
- outputs: headphones [master: front output:/headphones: rear output]
- sound card: 4.1 card [speakers (2-N4)]
That should fix up the cue in headphone issue so others can't hear
what you are readying up to mix next.
also, assign 1 and 3 on x fader for the left side, and assign 2 and 4 for the right
to enable the crossfader for 4 decks.
sound setup:
- input: none
Posted Sat 16 Mar 13 @ 11:52 am
