Posted Thu 01 Feb 18 @ 3:06 pm
Yes it can hear it,I am playing a record and you can see the waveform moving..so I can use it then..? where do I get a timecode from then ..?? on the web no DJ places where I live,can't buy records no more in shops,well no Our Price any more.. :(
Posted Thu 01 Feb 18 @ 3:30 pm
So I can only use VDJ timecode for 10 mins or pay $149...why,I don't make money from it I just want to feel like I am playing a record so I am using my record player as a controller really ,it for home use,so every 10 mins I have to restart VDJ then..??
Posted Thu 01 Feb 18 @ 3:40 pm
Vinyl can be bought from https://virtualdj.com/buy/controlvinyl.html
A timecode license for home use is indeed $149.
A full license for pro use is $299 or $19 per month.
Posted Thu 01 Feb 18 @ 3:47 pm
Can I use this timecode with it do you know..? http://www.ebay.co.uk/itm/2x-Serato-Performance-Series-Timecode-Vinyl-Record-for-DVS-DJ-PAIR-PINK-12/152113129407?epid=2256060963&hash=item236aa627bf:g:LbwAAOSwqBJXUGQJ
Serato vinyl is indeed also supported, so that will work as well.
Posted Thu 01 Feb 18 @ 3:49 pm
sorry one more question, can I use the BLACK PAIR $9.99 from https://virtualdj.com/buy/controlvinyl.html ..?
If Yes I buy them now..????
Posted Thu 01 Feb 18 @ 3:50 pm
Yes, surprisingly Virtual DJ's own timecode vinyl works with Virtual DJ.
Posted Thu 01 Feb 18 @ 5:30 pm
I think this are the Best Turntables for Mixing with VDJ 7 and VDJ 8,
some of this are gives not more we the very nice and expensive Thorens TD 524 / 535
or the Old Models of Technics SL 1200/1210 MKII (Only Second Hand)
But technics have make some new Models for DJing and Audiospecies. ;)
Technics SL 1200 / 1210 MK II
Technics SL-1200MK2
Technics SL-1200MK3D
Technics SL-1200MK5
Technics SL-1200MK6
Technics SL-1210M5G
Technics SL-1210MK2
Technics SL-1210MK5
Technics SL-1210MK5G
Technics SL-1200 GAE / G
Technics SL-1200G
Technics SL-1200GR
Technics SL-1210GR
Thorens TD 524
Thorens TD 535
Vestax PDX-2000 MK2
Vestax PDX-3000
Denon VL12
Pioneer PLX 1000
Pioneer PLX 500-K / 500-W
Mixars LTA & STA (Neu auf dem Markt / Doppelte Ausgänge)
Reloop RP-8000
Reloop RP-7000
Reloop RP-7000 MK2
Synq X.TRM-1
My Hobby: Search for Old Models of DJ Turntables for the List:
Have make a list for all DJ Turntables Models from beginning the 60` since Today that are gives.
For more Old international DJ Turntables Models i search often but not cant find:
Complete List and More here:
http://de.virtualdj.com/user/vlnjacki/blogs/5657/Info__DJ_Plattenspieler_(Turntables)_und_Laufwerke_von_damals_bis_heute.html
Technics SL-1200MK2
Technics SL-1200MK5
Technics SL-1200MK6
Technics SL-1210M5G
Technics SL-1210MK2
Technics SL-1210MK5
Technics SL-1200G
Technics SL-1200GR
Technics SL-1210GR
Thorens TD 524
Thorens TD 535
Vestax PDX-2000 MK2
Vestax PDX-3000
Denon VL12
Pioneer PLX 1000
Reloop RP-8000
Reloop RP-7000
Reloop RP-7000 MK2
Synq X.TRM-1
Posted Fri 02 Feb 18 @ 12:43 pm
are all time code vinyl created equal?
is there a 'best'
or just personal preference?
is there a 'best'
Posted Fri 02 Feb 18 @ 2:00 pm
http://www.virtualdj.com/manuals/virtualdj8/settings/audiosetup/timecode.html
Waiste not which is the best i dont use Timecode,i use a VMS 2
Posted Fri 02 Feb 18 @ 5:45 pm
Hi there if you got money go for Technics 1210's second hand or Pioneer Plx 1000 these are quality built! = they will last.
If you don't have a lot to spend then go for Reloops 700 Mk2, Buttons are not quality ,they are poor made = probably buttons will not last.
When you buying dj equipment you should consider will you invest on something what will last or if you are person who like buying and changing equipment very often?
let's put it this way :buy cheap means buy twice!
Posted Fri 02 Feb 18 @ 6:13 pm
Best Advice given on this thread. Ive had the same Tech. 1200s, since 1989. In 1993 I sold them to a friend, bought them back in 1995. Other than cleaning and fixing 1 pitch control they still solid.
Posted Sat 03 Feb 18 @ 11:59 am
And even if you have to fix something like the pitch, just watch 2 youtube videos and fix it yourself.
I did it that way and it worked perfect. Actually I didn't change the pitch (which is even easier), I just removed the pitch click.
And because the TT was already dismantled I changed the needle lamp to LED.
Posted Wed 07 Feb 18 @ 9:38 am
A lot people saying for Pioneer plx are not good, I think they are wrong: but based on that I had 1210's before they are not far of.
PLX1000 are not Technics but they are built like tank as well!
PLX are quality decks!
Posted Wed 07 Feb 18 @ 9:47 am
Time will tell but I've a 1979 built 1200 and it's still going strong, so the plx's have a way to go yet.
Posted Wed 07 Feb 18 @ 9:56 am
I know 1210's was the best but Pioneer plx 1000 taking over now!
Posted Fri 09 Feb 18 @ 1:31 pm
Well there's only one way to be sure, I'll tie a rope round my 12 you tie a rope round your plx and we go head to head with a turntable conkers death match XD
Posted Fri 09 Feb 18 @ 5:35 pm
Now that I'd like to see!
Everybody using plx 1000 even we still got the new technics turntable
some people still consider it technics as a Hi fi deck
I have been in a couple of dj shops and they don't sell them because of that reason they stated they are not dj decks,that is politics now!
I think that is an old Technics strategies of sales , if they say that deck is a dj deck many people won't buy it ( except dj's only ), if they say it's got that hi fi quality they can pull more people to buy it and also plus this deck is good for dj's. so that makes to merge more people around to buy it ,I think they made mistake this time.
It simple did not work this time!
we got the bigger choice that is a problem for Technics!
I know PLX 1000 is not an Technics 1210's but I'm sure it's built like tank!
it's good for dj's and it's good price to!and a lot dj 's use PLX 1000
Posted Fri 02 Mar 18 @ 4:09 pm
