Im use vdj le for the ddj ergo and when i load a track into a deck im gtting sound distrotion or rumbleing? any solutions to this problem?
Posted Sat 04 Feb 12 @ 5:25 am
Please see our FAQ pages:
https://virtualdj.com/wiki/Performance%20Issues.html
Make sure that you also have the latest drivers installed: https://virtualdj.com/wiki/Common%20Device%20Drivers.html
And the latest VirtualDJ LE from https://virtualdj.com/download/updates.html - Register your LE serial number on the page https://virtualdj.com/users/edit.html to be able to download this.
Posted Sat 04 Feb 12 @ 12:57 pm
I had similar issues.
Fixed by changing the latency to a lower number and clicking on ultra low latency in the options.
Hope this helps.
Hope this helps.
Posted Thu 09 Feb 12 @ 1:15 pm
I have encounter distorted sound with hercules it does works to smoothly for a few tracks then it will distorted what i did is just reinstall everything and if works fine now. If it doesn't work with the solution suggested above you un-install the VDJ and get updated firmware driver and re-install again and it will works.
Posted Fri 10 Feb 12 @ 3:01 am
