I experiences problems When i loop in Virtual DJ 7 . The Loop doesn't meets da Right Edges of the song i mix wit ... It either Delays for a sec or so .. can anyone help me Plss..... When i was working withe the Virtual DJ 6.01 ... I think everything was perfect for me... Including the 1 1/2 loops and everything was excellent and was in da Right Way .. can anyone help me Fix It... Im Not happy at all .. It makes me fail at Gigs all the times.....
HERE IS A SAMPLE OF HOW IT REACTS....
http://hulkshare.com/tqa6xd1ttxmc
Posted Mon 07 Nov 11 @ 11:32 am
It all sounds on beat/in sync to me.
You might need to adjust the position of the beat grid, if you feel that the loop is early or late.
Posted Mon 07 Nov 11 @ 2:07 pm
its your timing, because there is nothing that can set it on beat in your LE version, but it still sounded pretty good... if you get pro you can download a plugin called "loop games" which I just discovered can set the loop in point on the next upcoming beat on the cbg, it gives perfect loops on the beat everytime, your other option is to use the loop move knob on the skin to move the loop into position, but with such short loops not relly ideal.
Posted Mon 07 Nov 11 @ 2:29 pm
@ groovindj .. How can i do that .. can You teach me that ,, Im getting Pissed and Im planing of Going back to my Virtual Dj 6.01 Pro.. I have all Versions of da VDJ and all re pros.. I just dont wana Attach it to ma Profile and decided to add this up only to ma Profile.. can you help me Plzzzzz .. How can i Go about and Fix dat .. You already Know X max is Just around da Corner and im gona Play soo many Gigs.. so i gotta Fix ma Self b4...
Posted Tue 08 Nov 11 @ 5:30 am
@ synthet1c .. Thankx a Lot tooo But its Not Timing .. I use to be doing it in a Perfect way when i was using da V 6.01 .. Its not any Timing ... I think its a Problem .... Just Study it well and Figure it for meeeeee... And Not that i that i dont have teh Pro version of VDJ.I got teh Pro version for 7 and all .. I just dont wana Register it to my account here... Im Ok with this Key here .. .. How can i go downlaod dat Plugin... is dat Effect or...
Posted Tue 08 Nov 11 @ 5:41 am
Why wouldn't you want to register your pro version, it's not as if you could sell it on anyway, very unusual.
Posted Tue 08 Nov 11 @ 7:08 am
He's just sent me a private message asking for help too...
Spinash, register your software and we'll help.
Posted Tue 08 Nov 11 @ 7:49 am
I seee.. I will provide .... so re you guys still tryng to tell me you cant tell me any other wise unless i have a serial added. Just hellllp !!!
Posted Tue 08 Nov 11 @ 12:25 pm
Register your software and you have been given a possible way to fix your problem further up the page, plus you will be eligible to get your hands on all those extra plugin goodies. I'm still baffled as to the purpose of not registering though.
Posted Tue 08 Nov 11 @ 2:22 pm
@ Tyla... It Isn't Fair. I think i have da Virtual DJ Le and you can even see its even attached to my Profile so how come you ask me again to Register ma Serial and soo On .. It isn't fair. The VDJ le is da Same VDJ 7 and that's what im talking about ..If you have any Help and Assistant better help and forget about the registering it to ma Profile and whatever bro.... if i may Kindly ask ... is da Registration or whatever Gona reveal da Anser to ma Situation im facing or help me sort ma Problem now.
Sorry ... Sounds harshy .. Is Cuz of ma English ... Forgive.
Posted Fri 11 Nov 11 @ 10:33 am
You may be not understanding me correctly, I was trying to help you, if you have the pro version register it because as already pointed out you will get access to plugins that may be able to help your situation, that is why I keep mentioning to register your pro version that you say you have.
I don't care if you are an nlu or a pro version user, I try to help where I can and a starting point has been given to you, try that first and if you still have no luck come back here and the guys will see if they can help.
best of luck.
best of luck.
Posted Fri 11 Nov 11 @ 3:15 pm
Alllryt ... I have all access to Plgins and all things.. Cuz i have da LE registers and that Options has beeen opened to me... I just dont know .. Will see if i can attach dfa pro key soon to see what you can do to help me.
Posted Sat 12 Nov 11 @ 5:44 am
