Anyone else have this issue, whenever you play a sample, the volume is either too high or too low as compared to the volume level of the active deck that is playing. Can use the volume sliders to adjust each sample bank but would like a way to automatically match the levels of both the sample of choice and the active deck before firing off that sample? Perhaps a feature worth considering.
Posted Mon 12 Sep 11 @ 10:00 am
Seems common sense enough that by default the sample should match the deck volume.
Make is so number one.
Posted Fri 16 Sep 11 @ 11:07 am
This would be helpful, no doubt...
Posted Sat 17 Sep 11 @ 9:21 am
Yea.. Imagine when everyone is sleep in the house and master volume is 1%
Whenever you play a kick sample, you hear a sound like an explosion!! Because sample volume is 100%
I thought about auto match with Master Volume before
but now I think match with gain of Active Deck is better
Posted Tue 20 Sep 11 @ 8:14 am
Definitely match gain of active deck.
Once again i have to say that this is a must as a default option.
Posted Wed 28 Sep 11 @ 10:16 pm
you would need to do a bit of setting up to make this work, but a possible workaround for this could be...
-normalize all your samples to something like +6db with a program like mp3 gain
-map your sampler play button to set the volume depending on the level of the gain on the default deck
deck default gain 50% ? deck default sampler_volume 90% & sampler play_pause :
deck default gain 49% ? deck default sampler_volume 88% & sampler play_pause :
deck default gain 48% ? deck default sampler_volume 86% & sampler play_pause :
deck default gain 47% ? deck default sampler_volume 84% & sampler play_pause :
deck default gain 46% ? deck default sampler_volume 82% & sampler play_pause :
deck default gain 45% ? deck default sampler_volume 80% & sampler play_pause :
continue the pattern, delete the gaps and your done..
then again if you normalize your samples you won't really need to set the volume everytime
Posted Wed 28 Sep 11 @ 10:58 pm
Hi,
in the mapping of my Hercules RMX i have set by the Master Volume Slider:
Master Volume & sampler 1 volume & sampler 2 volume & sampler 3 volume......
So the Volume of every Sampler changes when you move the Slider of the Master Volume up or down.
But then in my case, a few samplers are too loud.
There should be a way to say "sampler 1 volume 50% to Master Volume, sampler 2 volume 70% to Master Volume...."
But i havenĀ“t any solution yet.
Posted Tue 18 Oct 11 @ 7:50 am
Workarounds are nice but the bottom line is that this should be a default option already built into the software.
Posted Wed 19 Oct 11 @ 2:08 am
Yes, i think so too.
There should be a master volume for the sampler bank which changes if you move the master volume of the decks.
And then adjust the sampler by its own with the volume slider of each sampler if they are too loud or too low in relation to the music.
I think that were the best solution.
Posted Wed 19 Oct 11 @ 8:47 am
