dali je moguce neke tipke sa numark mix track-a pro programirati recimo da pustaju semplove iz virtual dj , znaci kad kliknem na njih ide semple koji sam ubacio u program?
drugo pitanje:
PC:
Inputs: None
Outputs: Headphones (Master: Chan 1&2 / Headphones: Chan 3&4)
Sound card: Numark
Click APPLY.
Plug a pair of amplified stereo speakers into master output on the back of the MixTrack Pro and your headphones into the headphone socket of the MixTrack Pro.
NOTE: It's not possible to record or broadcast with the microphone on the MixTrack Pro. This is because the mic is hardware-based and routed directly to the output of its sound card. The audio signal from the mic is not sent to VirtualDJ, so it is not possible for it to record/broadcast it.
učinio sam sve kako gore kaže ali i dalje ne čujem 2 kanala kad oću miksat dvije pjesme htio bi čuti obe dvije u slušalicama bez da koristim externi mixer
drugo pitanje:
PC:
Inputs: None
Sound card: Numark
Click APPLY.
Posted Tue 16 Aug 11 @ 7:36 pm
cao
koju verziju Virtual DJ koristis ?
Posted Wed 17 Aug 11 @ 5:50 am
7.0 mislim
Posted Wed 17 Aug 11 @ 7:05 am
sa sampler files:
to je malo tesko ako jos nikad nisi uradio.
Trebalo bi ovako da zvuci u mapper XML:
za sampler 1
<map value="SAMP1" action="var '$samp' ? sampler 1 play_stutter & sampler 1 select : var '$shift' ? sampler 1 play_stutter & sampler 1 select : sampler 1 play_stop & sampler 1 select" />
Porbaj ovo od DJlimoo
za tvoj problem sto ne cujes u slusalici:
http://www.virtualdj.com/wiki/MixTrack%20Pro.html
http://www.virtualdj.com/homepage/Blulite/blogs/4511/Headphone_Setup_and_Usage_Guide.html
mozda da glupo zvuci, jel sie probao da upotrebas dugmo cue?
Sta cujes na slusalicama ?
Imas Pro ili LE
za sampler 1
DJlimoo wrote :
Možda ti ovo može pomoći.
1.Spoji vfx kontrolwer na računalo.
2. Potom otvori VirtulDJ.
3. Klikni na Config (desno na vrhu virtual DJ-a)
Otvorit će ti se prozor Settings.
4. Klikni na karticu Mappers.
Gore desno je lista uređaja koje je VirtualDJ prepoznao. Izaberi svoj vfx kontroler ako ga ima (morao bi biti).
Kad si to učinio, ispod toga bi se trebala pojaviti lista tipki (Key) (tu se misli na potove, fadere, tipke itd. tvog vfx kontrolera) i lista radnji (Action) koje su tim tipkama dodijeljene (koje one obavljaju). Ako ih nema ili nekim faderimai, potovima, tipkama itd. tvog kontrolera nisu dodijeljene radnje ili su pogrešno dodijeljene (ne rade ono što bi trebale), onda ruke na muke i polako ovako…
4. Klikni na plus tipku na dnu prozora (uključuje se desno gore Key-Learn tipka)
5. pomakni, stisni, okreni što li već određei fader, poti td. na svom kontroleru. Pojavit će se opis tipke u izborniku pored Key-Learn tipke.
6. Klikni na tipku Action – Learn. Prozor mapper će nestati kako bi ti otvorio VirtualDJ i na njemu izaberi radnju koju želiš dodijeliti tvom potu/faderu na kontroleru.
7. Klikni na određeni element na VirtualnomDJ kojeg želiš da taj fader na tvom kontroleru kontrolira.
8. Ponovno će se pojavit prozor mapper.
9. Nastavi tako fader po fader, pot po pot i to ti je to.
Primjer:
Klikni na tipku plus.
Pomakni crossfader na tvom kontroleru.
Klikni na tipku Action-Learn (prozor mapper nestaje i pojavljuje se Virtual DJ)
Pomakni crossfader na Virtualnom DJ.
I tako za svaku tipku tvog kontrolera. Zapravo, kad dodijeliš prvu radnju., stani, zatvori prozor mapper i isprobaj da li funkcionira tj, pomakni crossfader na tvom kontroleru i gledaj da li se pomiče crodssfader na Virtual DJ. Ako da, na konju siI
Nadam se da će funkcionirati.
Pozdrav
DJlimoo
Primjer:
Pozdrav
DJlimoo
Imas Pro ili LE
Posted Wed 17 Aug 11 @ 9:43 am
Problem sa slusama rijesen , pokusat cu programirat sutra hvala
Posted Fri 19 Aug 11 @ 5:43 pm
