Forum: Old versions
Topic: Need help please with Midi Mapping
SOLVED
I'm sorry if this is the wrong section, posted here because I found a similar thread to mine here.
Hello,
I'm new here, and I have been using Virtual DJ for few months.
I have version 7.
I'm trying to configure a Midi Controller.
It's via an application for Android (Dj Control).
So here is my issue.
I'm want to make the play_pause command for the left deck.
And another play_pause for the right one.
I have been trying for like two hours with all I found on the forum.
With action_deck 1
leftdeck
I'm sure there is a simple thing, but I can't figure it out and I'm going crazy.
Could you please help me ?
What should I enter for the command to work on deck 1 or 2. Or left/right.
I only use 2 decks.
Thank you in advance,
Raf
Posted Sun 10 Jul 11 @ 1:21 am
deck 1 play_pause
deck 2 play_pause
Thanks a lot.
I appreciate :)
Would offer you a beer if you where here haha
is there detailed instructions on how to make this work RAE (what to download and install
I'm used Acer Aspire Core i3 - DDR3 4GB and win 7 Pro 32bit
Virtual Dj 7 pro
And I wanna make midi wifi controller from my android (Dj Control) to virtual Dj in my laptop..
I've installed and follow the instructions, but still can not connected right between Dj Control from android (playstore) to Virtual Dj 7 on my laptop..
anyone can solve my problem ??
thank you for your attention and suggestion or solve my problem :)
The thread you are digging out is older than 3 years. So i will close this one. Feel free to open a new thread instead.
Please register your version of Virtual DJ Pro Full cause at the moment you are listed a Home Free user only.
Greets, Heiko
[closed]
