Forum: Old versions
Topic: Virtual DJ will not read wav files
I've just transferred my PC downloaded files to my MacBook Pro Laptop external hard drive. Virtual will not recognize files with a .wav extension. I have checked the 'CODECS' but nothing has changed. I really don't want to re-load 20k songs to make them mp3 files. Help!
Posted Wed 22 Jun 11 @ 10:08 pm
hmmm i got the same issue?
Make sure wav | WAV decoder is listed in CONFIG -> Codecs
Also, check the format of the WAV files themselves. They must be standard 16-bit 44.1Khz (CD quality) - 24-bit and 32-bit are not currently supported.
I HAD the same issue...here is how i solved it...i imported the track in audacity( the free audio editor ) the in the preference menu under export i made sure that my export was in 16 bit...exported...and voila everything is fine...
Thank you macsly! Worked like a charm..
