Forum: Old versions
Topic: Problem Virtual dj Skin Mac
salve
ho installato virtual dj le che mi hanno dato insieme all'hercules mk4 ma appena parte mi esce un errore " Skin no valida (errore linea %!)"
Come posso risolverlo ?
Posted Mon 23 May 11 @ 8:20 am
Hello,
There are 3 possible explanations:
- either you have installed VirtualDJ on a computer which had another version of VirtualDJ installed before, and you have a conflict of resources, then you should uninstall all versions of VirtualDJ, reboot and re-install VirtualDJ 6.0.7 Mk4
- or your computer is running in a non standard resolution, please precise it,
- or you try to load DJ Console Mk4 skin with an earlier version of VirtualDJ than VirtualDJ 6.0.7 LE Mk4.
Sorry, this forum is for English language messages only. Please either post your message again in English or post in the appropriate language forum at the bottom of https://virtualdj.com/forums
