Hello, I just ordered a new Numark Mixtrack. I am wondering if anyone has any suggestions on external sound cards so that i can cue into headphones. I currently have a fast track pro and i'm wondering if this will work? if so does anyone know how to set it up properly?
Thanks
Thanks
Posted Sun 22 May 11 @ 8:26 pm
To use the Mixtrack without pro, you need the Pro version of Virtual DJ. Please buy one copy, be shure you have tried and done all told by the Manual of VDJ and please ask again if the problem is holding on.
To by Virtual DJ please visit:
https://virtualdj.com/buy/
C.hackl
C.hackl
Posted Mon 23 May 11 @ 1:58 am
If the MixTrack came with VirtualDJ LE then it can be used in master + headphone configuration with a suitable multi-channel DJ sound card such as Numark DJIO, Native Instruments Audio 2 DJ, etc.
Fast Track Pro is a 4-in, 4-out card so should be suitable.
VirtualDJ LE is limited software, but it can be upgraded to the full Pro at a discount by going to https://virtualdj.com/buy/
Posted Tue 24 May 11 @ 4:35 am
