This was easy... CDG+MP3 over Flash in VDJRobot (no background, added music responding visualizations in background)
http://i55.tinypic.com/2rmt8xv.jpg
Posted Wed 18 May 11 @ 5:31 pm
wallter wrote :
Flash can easily parse CDG background: http://www.as3.ro/blog/wp-content/uploads/2010/04/cdg.html
Yes but this shows me that i can not be to difficult to play them without background, so it must be possible to crate an plugin which can do that....
Don Moir wrote :
The few CDG files I did play back worked pretty good. The text was very clean. It depends largely on the CDG file itself but mostly I think these files have clean text with perhaps some iniital backgrounds. Is that correct ?
not sure, but use some files from my package, its one title from different producers, and some german title too
Posted Thu 19 May 11 @ 5:03 am
I showed you how Flash can handle CDG's. VDJ has an CDG filter inside the application, allowing it to read and display CDG data on the display. In short, VDJ developers should upgrade this CDG filter to make your dreams come true ;-) There is a way over Flash plugins, but then you'll have to load CDG songs over plugins, and I think this is not what you've been asking for. But, I've had some extra time and played around. Good luck...
Posted Thu 19 May 11 @ 6:44 am
Luciano, sent you a PM
Posted Fri 27 May 11 @ 4:22 pm
I would also like to do this as well. There is karaoke software out there that does it already, Karafun
http://www.karafun.com/karaokeplayer/features.html
I also think Swift elite does it and thier free player.
http://www.tricerasoft.com/Free%20Karaoke%20Player.html
I am thinking if these free softwares can do it. it should be simple. I am no programmer tho. I did hear reaserching this years ago the background in most CDG files is set in one line so the pluggin sould see the line of program say "background color XXX" and change to "background color Clear" once again i am not a programer as you can see but that is how I think it was explained to me years ogo.
VDJ Rocks for karaoke this pluggin would put it over the top!
Dave
Dave
Posted Wed 15 Jun 11 @ 10:24 am
