Hi there,
VDJ5 worked so well for me! More than 2 years I used it with succes. I have an External Mixer with 2 USB, Mic and Headphone plugs and my Soundconfig was the following:
Input - None
Output - External Mixer - Left Deck: Left Card, Right Deck: Right Card
Soundcards - 2 Cards - USB Audio Codec (1), USB Audio Codec (2)
When I wanted 2 record my set, I would connect the Record Out of my Mixer with the Sound System (because it is very loud) and the Master Out with the Line-In at my PC. It was no problem to tell VDJ5 to just record the Line-In...
But now I upgraded to VDJ7 and it suddenly is!
When I keep my settings like in VDJ5, I cannot record the Line-In anymore, instead VDJ7 is recording the 2 USB-Channels. That's not ok, because then I wont be able to prelisten to any tracks with my headphones anymore, because as soon as I prelisten this will be recorded as part of the mix, but I just wanna record the Master!!!
So I gathered some intel and found that you have to go to Advanced Config, to make the recording work. And I fixed it,....but what the heck....now my Mixer wont work anymore!!! I tried almost every combination, but it just wont work, the way it did before. Example:
Line-In1 - Realtek HD Audio Input - Input1&2
Deck1 - USB Audio Codec (1) - Output1&2
Deck2 - USB Audio Codec (2) - Output3&4
I can record with these settings, but every track I play with VDJ will be sent to the left Deck on my Mixer. I can't mix, if I can use only one Deck!
HELP PLZ
Input - None
HELP PLZ
Posted Tue 03 May 11 @ 8:02 am
When you say "upgraded" is it a registered copy of VDJ7 from this site or a cracked copy from the internet?
Keith
Keith
Posted Tue 03 May 11 @ 8:21 am
Please register your software to this page https://virtualdj.com/users/edit.html to receive the latest updates, or buy a license https://virtualdj.com/download/updates.html
You can use the Home Free Version https://virtualdj.com/download/free.html for 10 minutes with your current setup to test the software.
Your Advanced Sound config should be ..
Deck2 - USB Audio Codec (2) - Output1&2
RecordLoopback - Realtek HD Audio Input - Input 1&2
Posted Tue 03 May 11 @ 9:36 am
At last someone who can give answers about the recording... i have 2 cdj 400 and pioneer 600 and i want to record Through the line in with vdj rcording, How to configure the advanced settings ? Thanks
Posted Tue 03 May 11 @ 6:57 pm
Route a proper cable from your mixer's booth or rec output to the line-in of your internal sound card (pc or laptop). make sure that it is not muted from Control panel.
Advanced Sound setup
Deck 1 .... CDJ400ASIO ..output ch 1&2
Deck 2... ..CDJ400ASIO ..output ch 3&4
RecordLoopback.. Your internal sound card name ... Inputs 1,2
Posted Tue 03 May 11 @ 10:20 pm
It does not work I tried number of ways...
Posted Fri 06 May 11 @ 6:04 am
What do you mean it doesn't work?? No sound at all, the sound is really bad? What format are you recording to?
Huey
Huey
Posted Fri 06 May 11 @ 9:40 am
