What is a cheap good external sound card to get for my notebook?
Flame
Flame
Posted Fri 29 Jul 05 @ 11:54 pm
Is the Sound Blaster Audigy 2 NX External USB Sound Card any good? Since it can go 7.1 ??
Thx
Flame
Thx
Flame
Posted Sat 30 Jul 05 @ 7:07 am
Any external soundcard will do :)
It you are looking for cheap soundcards, Soundblaster got some....
Look for soundcards having 4.1/5.1/7.1
That will let you have 2 x stereo out, if you are going to connect it to an external mixer
Posted Sat 30 Jul 05 @ 3:00 pm
if u want to hook up turn tables and a mixer, those wont work, u will need 4 in and 4 outs, and ASIO capabilities, the best one for that would be the maya44, but i have also heard good things of the delta44
Posted Sun 31 Jul 05 @ 2:50 am
i only need a 2 or 3 line out for the mixer, i have the dac-2.
Posted Sun 31 Jul 05 @ 7:53 am
sry, but i no nothing bout dac-2 , sry cant help u out on this one...
Posted Sun 31 Jul 05 @ 8:45 am
---> Sound Blaster Audigy 2 NX USB, works OK for me.
Posted Sun 31 Jul 05 @ 9:05 am
If you don't plan to get or use TCV's or TCDDs, The Soundblaster Audugy 2 NX USB works perfect.
Posted Mon 01 Aug 05 @ 8:25 pm
thx, i orderd it. Why dont it work with TCV's ?
Posted Tue 02 Aug 05 @ 6:24 am
Because you need 4 inputs (2 Line or 2 stereo inputs) with ASIO drivers to get full functional your TCV set. The only probe USB sound card is the Maya 44 USB. Another posibilty is use the M-Audio Delta 44. The main thing is that you need an ASIO card with 4 inputs (or more) to use the TCVs (and it's better if you use a soundcard that it's already probe with VDJ)
Posted Tue 02 Aug 05 @ 7:42 pm
