Hi guys first post here and looking for some help, i`m going to start usin vdj but i want to build a system to run it on before i buy it, what i need to know is what will i need to build this system? i know there is minimum specs that vdj recomend and prefered specs then there is the specs you guys use, realistically what specs do i need to use vdj reliably without goin over the top, i wont be mixing video at all so we are talkin mp3 only mixing for party`s, weddings ect. i`m planing on building the system around a 2u rackmount can you see any probs with this.
any help would be much appreciated and i`m sure there will be loads more questions
Posted Fri 29 Jul 05 @ 10:21 pm
Anyone?
Posted Sun 31 Jul 05 @ 1:51 pm
Any new good PC will be able to play VirtualDJ smoothly. If you plan to build a personal rack see Cyder's advices.
Posted Sun 31 Jul 05 @ 2:00 pm
hola mi nombre es carlos y me gusta bastante este programa es super bueno
Posted Sun 31 Jul 05 @ 11:40 pm
Carlos, este foro es en inglés. Te recomiendo acceses el SPANISH FORUM donde es en español. Y claro el programa es sensasional!. Un Saludo!
Traslate: Carlos says he likes VDJ and it's so good. I respond that this forum is in english and there is an spanish forum and he can go there.
Voodoo123uk, read these posts, will help you:
https://virtualdj.com/forum/display.html?topic=14111
https://virtualdj.com/forum/display.html?topic=13999
https://virtualdj.com/forum/display.html?topic=13943
acw_dj
acw_dj
Posted Sun 31 Jul 05 @ 11:56 pm
