This should be possible but not sure how it would affect performance of vdj :
Using Toshiba 2.4 laptop w/ 512MB.
Currently using maya 44 in asio mode for timecode cd playing…
I want to purchase a 2nd cheap soundcard for my laptop(since my internal sc doesn’t have a line-in) to receive the output from my external mixer and record my mixes into mp3 file.
Any suggestions?
Any suggestions?
Posted Wed 27 Jul 05 @ 8:50 am
use the mic-in. most onboard sound cards dont have dedicated mic pre-amps, there jsut normal line level ADC's with different gain settings, which usualy means there sterio too. yours may not be but just check it mite save you a fair few quid if all you want to do is record your mixes.
Posted Thu 28 Jul 05 @ 12:39 am
