Forum: VirtualDJ Plugins
Topic: SBDJ TweetList - Page: 6
Pleeeease fix Auto-tweet issue. I'm advertising my playlists are on twitter, but I keep forgetting to turn the faulty option on.
I tried installing the old beta version, as it used to remember the setting, but it wont register with twitter anymore, probberly because of the new versions release.
Pleeeeeeeeeeeease....
I'm sure it was deliberate to stop it from tweeting every time which I didnt think users would want.
I could add a remember option, or you could use VDJScript with a skin element?
Remember option would be awesome, I'm still forgetting to turn it on each time. The older version did remember.
Or a button called "Auto Start", "Auto Run" maybe?
Or you could just tell me how to add it to the skin please?
Anyone? I can mod skins, but controlling certain buttons of a plugin is above me. =(
Thats the easy part:
toggle '$sbdj_auto_tweet'
That command toggles the auto tweet button. You could easily add that as a skin button :)
How does VDJ know what plugin that command is toggling?
Is there a way of just turning auto tweet on without having to hit a button? just a command I can embed in the skin that turns on auto tweet, not toggle, as toggle may also turn it off again?
My plugin keeps an eye on that variable.
set '$sbdj_auto_tweet' 1
Awesome. will give it a shot. Thanks.
Ok, more help please, been two years since ive touched a skin, and Ive forgotten how to add a action to a skin, without a button.
Whats the whole command please?
Does this work?
<init action="set '$sbdj_auto_tweet' 1"/>
Sure does, thanks Scott.
Hi There,
When i click the \"SBDJ tweetlist\" in my version of Virtual DJ, i get a blank screen. What could be the problem?
It doesn't support VDJ LE.
tried on and off for about 2 hours to register it. It still gives me the page error. Set up the twitter account name and password is correct. clock and date are correct. any other tricks would be appreciated.
thank you
Scott, I posted this in the Facebook group too, but I keep getting this error when I try to register tweetlist:
There is no request token for this page. That's the special key we need from applications asking to use your Twitter account. Please go back to the site or application that sent you here and try again; it was probably just a mistake.
Id love to test the Facebook and Twitter version
v1.2 now available - it fixes the recent oAuth token issue so you can register again now, and I've also fixed a potential crash issue with the popup text boxes.
61%
