Forum: VirtualDJ Plugins
Topic: SBDJ TweetList - Page: 4
This plugin is now available for PC users. My OP has been updated with basic instructions.
Thank You!! Only wish I was at home so I could download it, lol!!
Downloaded and installed the plugin into "Other" plugins tab. I have been testing it out and putting it through its paces.
Seems to work ok but does not work well with firetext. If you are logged into a twitter account with firetext and a different twitter account with
SBDJ Tweetlist, it will not work. Firetext seems to override the account login. Should be a way to have it work with multiple twitter accounts logged in on the same ip at the same time. I am also having trouble getting it to work with firetext logged into the same twitter account.
Oh well. Will continue to test and see if I can find a way to get them both to work together.
Is their a way to log out of SBDJ Tweet List and then log back in? Reason being that multiple accounts seemed to work ok until someone sent a text to screen. At which time firetext sent the text to twitter and SBDJ Tweet List stopped working.
DJ James
Just noticed that the manual tweet function still works with firetext running. It is only the Auto Tweet function that is not working with firetext.
DJ James
I haven't tested its co-existance with Firetext since I don't have Fire text.
edit..
after retrying everything it works perfect
thank you Scott great job
Is their a way to make the #time# show up in normal time instead of military time?
DJ James
I keep getting this error, well not so much an error but this is the page that pops up when I hit register app.........
And the app doesnt show up under my apps tab in twitter.
What shall you have me do?
Strange. No firewall and clock is right on PC?
I have had a few days now to test it with firetext and have worked out the bugs now. It seems before my template was too long or had too many hashtags.
So I can use the Tweetlist plugin with my DJ Twitter account and then follow it with the clubs text to screen account so that all tweets go on the screen. Throw in some manual tweets with comments and it works really well for live on screen info and updates from the booth without much trouble
Another great plugin from SBDJ.
Thanks,
DJ James
Twitter -- @djjames1
Well lastnight I shut my laptop down and went to bed, this morning I fired it up and hit register app. Well showed me the number and everything is good now. I must of had a glitch in the system and re starting it fixed it, lol!
Had the same issue today when I got to work. But when I checked the clock it was off by an hour. Reset clock and re registered app. Working fine now. Not sure what changed my laptop time because that hardly ever happens. Could have been an update. Who knows. Working fine now.
DJ James
@SBDJ
Love the plugin....
Is it possible to make a #Date# function ?
So when you have gig's on both friday & saturday, it shows the date & time for each track ??
That way i dont need to copy my entire playlist for each day up, but just let my costumers finde the date I playd for them, and they can look at the playlist ?
One more question.. with the FB plugin.. is it gonna be possible to post it to a specific group you are a member of ??
(in my case we are a group of dj's that post tracks during a gig, for inspiration to other members of the group)
So it would be a very cool feature to have for the FB plugin..
i would like to try it to facebook and twitter
Twitter is already available. Facebook will be later.
SBDJ....
is my suggestion with the #Date# function possible ??
and the group post in fb aswell ??
Just saw this plugin last night. Works great, thanks!
Hi Scott,
Have downloaded and installed, initially couldn't see it. However have sussed out the issue.
I have moved my Virtual DJ folder in to my Dropbox so not in the default location. The installer is hard coded to \<user>\Documents\VirtualDJ
Can the installer not detect the location from the registry?
Also, second the request for date tag as well as the ability to support multiple templates would be good...
Cheers,
Roy
40%
