Hi i was wondering if i could be using my computers speakers and than play with another track through headphones out of my computer too. i cant really seem to figure this out at all.... im just a novice dj here trying to make some dj sets but i dont have the equipment to do so... so with the headphones though i could record and play around but i just cant figure it out .... any help would be appreciated.... thanks
Posted Tue 15 Feb 11 @ 2:13 pm
Assuming that you are using VirtualDJ Home FREE, then this is limited software and only supports the following configurations for pre-listening to music using headphones:
(1) If you are using a desktop PC with a 5.1, 6.1 or 7.1 surround sound card buit-in, you can use the front and rear outputs of this for master and headphones. Plug stereo amplified speakers into the front output socket and a pair of headphones into the rear output socket.
(2) If you are using a laptop, you can add a basic stereo USB sound card for the headphone output.
(3) You can use the sound card built into your laptop and the mono split option, however this will only give you MONO sound. You will need a splitter cable to split the left/right channels - Please search Google for: 3.5 jack splitter to mono
To choose which deck to pre-listen to, press the TAB key or click PFL button on the skin. Use the crossfader and/or volume sliders to control which deck is output live over the master outputs.
For more advanced sound configuration such as using two sound cards or multi-channel external DJ sound cards, you will need to purchase a VirtualDJ product such as VirtualDJ Basic or the full Professional: https://virtualdj.com/products/comparison.html
Advanced sound configuration and other Pro features such as MIDI controllers can be tried out for 10 minutes at a time, after which the software will revert back to free limited.
Posted Wed 16 Feb 11 @ 10:15 am
