Hi
Im trying to to set up vdj so Deck 1 (Left Top) is virtual and Deck 2 (Right Top) is virtual but I want Deck 3 (Left Bottom) to be a timecode and i wand Deck 4 (Right Bottom) To be rewired fpc. I am using a vms4 and a single stanton turntable with serato scratch live vinyl.
I am currently using the 8out mode config from https://virtualdj.com/homepage/djdad/blogs/4316/VMS4_Setup_Guide.html (Thxs to djdad) to control 4 virtual decks.
Is what im trying to do possible with my hardware and if you know a bit what settings do I need to change and midilog inputs to use to atleast get my time code running on deck 3 w/ 2 virtual decks on 1 and 2?
I know its a tall order but if anyone could please help me I would be so happy. Im going on a few days now trying to set up tc with no success. Although it did work fine set up in 2 deck mode controlling my left deck.
Thanks
Thanks
Posted Mon 31 Jan 11 @ 10:19 am
You can control any deck you wish 1...99 with your timecode, BUT you cant use all 4 volume faders (midilog chanels) using Timecode. In order to work the Timecode input, you need to switch to 4in-4out mode, meaning that you can use only the 2 chanels in the middle.
So in this case you have a normal 2 deck controller you can switch between the leftdecks, and the rightdecks.
Posted Mon 31 Jan 11 @ 4:04 pm
