Newbie wondering how to setup vdj pro with dnx1600. i have the system working completely usb perfectly for sound, and i have the 1600 mapper in the <plug in><mapper> location. vdj does see it in the mapper section in config but only as simple midi mapper. Any help much appreciated.. thnx
Posted Thu 27 Jan 11 @ 9:13 pm
In VirtualDJ v7 and v6, VDJscript mappers (See http://www.virtualdj.com/wiki/VDJscript.html ) need to be copied to My Documents\VirtualDJ\Mappers and definition files to My Documents\VirtualDJ\Devices.
NOTE: Old DLL-based mappers and general MIDI mappers designed for VirtualDJ v5 or earlier are not compatible with VirtualDJ v6 and above.
Posted Fri 28 Jan 11 @ 4:29 am
thank you
Posted Fri 28 Jan 11 @ 4:40 pm
