I have $2,000 to spend. What do you have that you can recommend for Video dj'ing?
I want your opinions all the way from the case to the monitor to the mother board. What do you use that works for you in VIDEO mixing. Give me a break down of all the pieces...
Monitor - monitor adapter
case
video card
motherboard
Whatever else you may know. I plan on getting a gig of ram, a dvd burner, and 400 gig hard drive. That is all set so set aside 500 for that. You now have 1,500 - 1,600 to spend. What should I get?
case
video card
motherboard
Posted Thu 14 Jul 05 @ 11:29 pm
check out my blog...
Posted Fri 15 Jul 05 @ 8:07 pm
