Installed skin V-mix. Seems okay but all of a sudden wjen I load a track, it starts too fr into the song. Example if a track is 3 min it starts at 2 1/2. This happens upon loading and doing nothing else. I have tried to use different skins and it is the same. Any suggestions? Need to try to fix as I have a wedding this Sat.
ALso I can't seem to find a way to set any cue points in this skin. Is there a way to set cues?
Posted Thu 14 Jul 05 @ 10:44 pm
steve turn off auto cue....
also use keyboard to set cues ctrl+ 1-9 and goto is alt 1-9
Posted Thu 14 Jul 05 @ 11:05 pm
Well kiss my right cheek & Make the right one jealous. Works Thanks.
I noticed BPM arre still pretty much off. Example; B & G first song is Saving All My Love For You - WHitney. BPM shows 167. I don't think so more like 65BPM.
Still a bit confused on changing names, but I can keep trying.
Really likely this skin. Now that you set me straight thing should be better.
Posted Thu 14 Jul 05 @ 11:51 pm
If you right click on the bpm then you can click the middle tab you can choose the option to divide by half. Changing names is best done thru explorer like I showed you and a database rescan to follow. I'll try can call tomorrow we have a huge convention in town and I have a 70 hour week to match :S
Posted Fri 15 Jul 05 @ 8:26 am
Yep, I know about dividing by 1/2 etc. Forgot about changing names in the database.
I'll play around with it a bit today. Once again thanks
Posted Fri 15 Jul 05 @ 1:09 pm
Check your anchors after resetting the bpm, they change sometimes.
Posted Fri 15 Jul 05 @ 3:01 pm
Rick
Didn't think about that, thanks.
Posted Sat 16 Jul 05 @ 2:21 pm
