Hey,
I'm looking for some help concerning mapping for the Numark Mix track Pro.
At the moment, all is set to factory defaults, wich suits me fine for now. All I would like is to have a function changed.
The scratch button on my controller makes it go into "vinyl_mode", allowing you to use the touch sensetive jog wheel to scratch and drag the track to your desired position. This part is fine.
When the scratch button is turned of the jog wheel functions as a pitch bender. Now this is what I would like to change.
I would like it that when scratch is turned of, that the jog wheel functions as a way to shift the position of your loops.
Now I have to use the mouse to turn the shift knob on Virtual DJ, but it would be ideal to have it controlled by my controller.
If this is in anyway possible I would really appreaciate the help. Below are the keys most likley to be used in making this mapping work.
Key: Action:
SCRATCH vinyl_mode
JOG_TOUCH touchwheel_touch
JOG touchwheel
If you need more info let me know!
Thanks in advance!
Key: Action:
SCRATCH vinyl_mode
JOG touchwheel
Thanks in advance!
Posted Sun 09 Jan 11 @ 3:51 pm
Hi:).Do you have a mapper for numark mixtrack pro?Because i never find one:|.thx!
Posted Sun 06 Feb 11 @ 12:06 pm
It is built into and natively supported (Plug and play) in the latest VirtualDJ v7.0.2 Pro: https://virtualdj.com/buy/
VirtualDJ LE (Limited Edition) does not support custom mapping.
You can upgrade at a discount from your VirtualDJ LE by going to https://virtualdj.com/buy/
Posted Sun 06 Feb 11 @ 1:56 pm
