Forum: Old versions
Topic: Cant open virtual dj le - Page: 2
How can i install a msi package as admin? I googled and found out that you need to edit registry?!
Posted Thu 08 Jan 15 @ 5:27 pm
It seems like there's two versions in the download section. When newer install_virtualdj_le_v7.4.2.msi 37 MB and one older install_virtualdj_le_lite_idjlive2_v7.4.msi 40 MB
I see the older has idjlive in the name ... very confusing! i picked the newer one 7.4.2 and i ran into the skin problem. Installing the one with idjlive in the name worked though!
Posted Thu 08 Jan 15 @ 5:40 pm
Why does my Virtual DJ le for ddj wego2 not appear on my screen? A text will appear about the skin it says that it has a higher resolution than my screen then when I press OK my Virrtual Dj LE wego2 is working but not on my screen? How can I fix this? PLS ANSWER ASAP.
Posted Mon 25 May 15 @ 3:33 am
What is the resolution of your screen?
In VDJ versions before 8, the skin resolution has to match the screen resolution.
Posted Mon 25 May 15 @ 7:30 am
