Sorry, its not about who's newbie and who is not. Sometimes even the most simple things are there to tell us our mistakes.
Btw, did you try the Advanced Sound Config?
Posted Mon 24 Jan 11 @ 8:52 am
i\'m not using 7.0 so there is no option for that. but here is a shot with 7.0 to exclude that idea too
so now what would you like me to try?
Posted Mon 24 Jan 11 @ 11:52 am
I noticed you have the wrong setup. I'm not a TC expert but you can check my blog ( https://virtualdj.com/homepage/djdad/blogs/4316/VMS4_Setup_Guide.html ) for the propper setup. Note that, in order to play Timecodes you need to set your VMS4 to 4out-4in mode, that means that you have only Output 1,2,3,4 not 5,6,..etc
Posted Mon 24 Jan 11 @ 6:04 pm
it is in 4 in 4 out mode. it can be set up BOTH ways with 4 in 4 out. that's how you set it up for single timecode use and 4 decks. unlike many others i read manuals and again i have used TC since TC came out with a laptop WAY before VDJ even thought of using it so i am VERY familiar with how to adjust settings and set it up. so i kind of concider my self somewhat of a TC expert concidering thats ALL i use and have used for 7 years.
if it was set up wrong why would i have a 100% TC signal and control with a TC signal of files? if it was set up wrong in 7 why would it do the same thing in 6.1.1 with the same results 100% TC signal and control?
but again for arguments sake and to rule it out i will set it up for 2 decks the way you suggest in your post and see if i get the same results and show the same 100% TC signal and control but then i ask you, after trying every possible thing suggested and EVERY possible setting change why do i STILL have the problems with latency settings lower than 30ms? did you scratch and cut like i did when you tested tc control? cause that's how i play and 30ms is not acceptable.
also your wrong about the 1,2,3,4,5,6,7,8 because EACH channel uses TWO one for left one for right so CHANNEL 1 would 1 & 2 (left & right) CHANNEL 2 would be 3 & 4 (left & right) and so on.
can i see your screen shot with TC control? curious to see your settings.
Posted Mon 24 Jan 11 @ 9:59 pm
