I'm using VDJ LE with the 20 day pro trial and a dnmc6000. I'm experiencing choppy sounds. Denon says it maybe latency settings but I'm unable to find any setting for latency in the performance tab of preferences area. Is the 20 day trial limited that it does have latency settings until I actually buy it? I really don't want to upgrade it if it's choppy like this.
Posted Wed 29 Dec 10 @ 12:37 am
During the trial you should have access to the CONFIG -> Performances panel, where you can change the latency setting.
If the trial is not active (or has expired), you will not have access to this.
To activate the trial, click on the button in CONFIG -> Advanced Options
Posted Thu 30 Dec 10 @ 7:53 am
I have the pro trial 'activated' already but there's nothing inside the performanes tab that seem allowing adjustments for latency. Here's a photo of my Performances page.
http://i80.photobucket.com/albums/j163/simonsez711/Screenshot2010-12-25at104351AM.png
Let me know what I need to adjust.
Posted Thu 30 Dec 10 @ 2:30 pm
Posted Mon 01 Jul 13 @ 6:35 am
This is an old post from 2010, so the user has more than likely solved the problem.
Other users who are experiencing 'choppy' sound should ensure that their computer has been optimised for DJ performance: http://www.virtualdj.com/wiki/Performance%20Issues.html
[Old topic closed]
[Old topic closed]
Posted Mon 01 Jul 13 @ 7:45 am
