I am having some technical difficulties starting with my timecode setup.It shows a "line" insted of a circle in the signal setup and is also playing the decks backwards...i have no clue how this happened i was using it just yesterday,powered it up today and to my surprise im facing this problem.If anyone could help me any help would be greatly appreciated thanks.
Posted Sun 12 Dec 10 @ 2:16 am
Sounds like 1 of your wires is loose. Check all your connections then clean your needles and try it all again.
Huey
Huey
Posted Sun 12 Dec 10 @ 2:22 am
tried plugging everything in and out still no luck
Posted Sun 12 Dec 10 @ 2:25 am
Well then maybe you need.new needles? If its only showing a line that's means its only picking up one side ( left or right ). If its playing in reverse you either have your wires backwards or you have "invert signal" checked. I think that's what its called. Its in the debug screen.
Huey
Huey
Posted Sun 12 Dec 10 @ 6:32 am
im only using one tcv and no the invert signal is not checked
Posted Sun 12 Dec 10 @ 2:55 pm
heres the link to the screenshot to give an image of the problem im working with i still havent found a solution....
http://img828.imageshack.us/img828/4517/tcverror.jpg
Posted Sun 12 Dec 10 @ 6:04 pm
Yup that looks like only one side is coming through. The timecode signal are in stereo so if both sides are coming through you get circles. I told you all I know maybe someone else will chime in.
Good Luck
Huey
Good Luck
Huey
Posted Sun 12 Dec 10 @ 6:11 pm
so i need to replace my rca cords?is that what youre saying?
Posted Sun 12 Dec 10 @ 6:43 pm
If you havent done it already I would say yes switch your cables.
Good Luck
Huey
Good Luck
Huey
Posted Sun 12 Dec 10 @ 8:06 pm
my cords have no wear or tear there almost brand new but if you are sure thats the problem then i will try
Posted Sun 12 Dec 10 @ 11:11 pm
Bro im not telling you to do anything ..................im just giving you a list of things to check and do. But it the same old story, im wrong and all your stuff is brand new and you have all your settings perfect. Have you cleaned or even switched out your 1 needle?? I've told you everything I know already.
Good luck
Huey
Good luck
Huey
Posted Mon 13 Dec 10 @ 6:44 am
thanks i just played with the cords and it eventually started working good lookin for the help
Posted Wed 15 Dec 10 @ 1:29 am
same problem again!smh
Posted Thu 16 Dec 10 @ 10:59 pm
now i have a whole different problem but its similiar take a look....
http://img576.imageshack.us/i/tvcerror2.jpg/
Posted Sat 18 Dec 10 @ 10:39 pm
^ what version r u using?
Posted Fri 07 Jan 11 @ 8:15 pm
version 6.07 i
Posted Tue 11 Jan 11 @ 4:15 pm
did u follow these instructions?
https://virtualdj.com/wiki/TimeCode%20Config.html
Posted Tue 11 Jan 11 @ 5:32 pm
it works on and off i really dont understand the problem i plug my setup into serato and it works perfectly
Posted Tue 11 Jan 11 @ 10:29 pm
reinstall the software
Posted Wed 12 Jan 11 @ 7:16 pm
