hey all im new to the forum, but love using this program! Recently i began trying to save some samples and when i try to reload them it does not work. all help is appreciated!
Posted Mon 06 Dec 10 @ 1:51 pm
How have you saved it?
NOTE: By default, recorded samples are not saved for use in subsequent
sessions. To save the sample, use the “Sample Options” menu and select the
“Save…” option.
“Save…” option.
Posted Wed 08 Dec 10 @ 5:32 am
I take it that this does not apply with the demo, or "free" version of this that came with the mix deck?..
Posted Mon 01 Sep 14 @ 7:12 pm
VirtualDJ LE is limited software and does not support loading/saving samples.
It only allows samples to be temporarily recorded on the fly (These will be lost when you exit the software.)
Posted Tue 02 Sep 14 @ 5:23 am
I got 7 Pro and it doesn't load saved samples from a previous session. How can the samples be saved after closing and opening a new session?
Posted Thu 05 Jan 17 @ 9:34 pm
