Forum: Old versions
Topic: VDJ 7+CD-J 350+DJ-M 350 Sound problem
Hi, I just got my CDJ 350 together with DJM 350, I set up both CDJ as a sound card in VDJ 7 using the DJM as an external mixer. It has minimum latency and it was also pre-mapped. now I don't have problem setting it up, but I do have problems with the sound quality, after using it for around 10 minutes the sound started cracking both in the headphones and the main output.
how do i fix this? do I need an interface to help with the sound problems? if so how do I set it up (I was thinking of purchasing Audio4 by native instrument)
Cheers,
Ben
Posted Wed 10 Nov 10 @ 6:55 pm
i have the same issue:
djm 350
cdj 350 x2
vdj 7
and after using it for around 10 minutes the sound started cracking both in the headphones and the main output. any further progress on this one, it only happens when its running vdj???
i have that same problem and tried to get incontact with one of the mods but he never got back to me. i found out a solution to get rid of it but not permantly. if it happens b4 u crossfade it open config and have it set on sound setup and press apply once or twice or thrice quickly and it should get back to normal and after that i wont happen well it shouldnt happen for a while, while ur mixing. but wen u re start VDJ it will haappen again. i hope iv helped u with ur solution and i hope they fix this bug
sorry about my english, is not the best
and i us 400's
Hi
I'm new to this forum and software...
I thought I would try the Virtual DJ / Numark Cue software as an all in one alternative to what I presently use and was impressed at how it searches and it's general layout, however having used it the other day, I found I had to revert back to my old software (Show Presenter for Karaoke and PCDJ Dex for Audio) because of a crackling noise through the speakers when using the Virtual DJ software.
I have searched this forum and tried a number of proposed fixes to no avail and someone mentioned that a ground loop isolator may resolve the issue.
Could crackling from the speakers be resolved by the use of this device?
I do not have this problem using my old software only through Virtual DJ which does seem strange.
I would seriously like to upgrade to the full version but unless I can resolve this issue, it would be money wasted so your help on this matter would be greatly appreciated.
Thanks
Please open your own new topic rather than hi-jacking an existing one that is not related to your question in any way.
To open a new topic, please click on the pen and paper icon at the top of the forum topic list page.
You question appears to have nothing to do with problems using Pioneer CDJ-350 + DJM-350.
Edit: It appears that somebody incorrectly told you to post in this topic instead of your original separate topic. Please see your original topic https://virtualdj.com/forums/144873/PC_Version_Technical_Support/Speakers_Crackling_On_Audio_Video_and_Karaoke.html for a possible solution and/or to continue discussion of your problem if necessary.
i think iv solved my problem with the crackling noise i use to get when i was mixing with my 400's.
i decided to check my sound setting via the icon on my task bar(bottom right hand cornner )
so i opened up my realteek HD audio manager and stuffed around with my DEAFAULT FORMAT tab.
it was on a differen Hz and put it to 16 Bits, 44100Hz (CD Quality) and it seems to b ok now, no crackling noises so far.
ill post anything up if i get them noises again.
I just got my players a couple days ago and use virtual dj 7. Every thing works fine except if i do a backspin on a player the one running will freeze. If anyone has been through this and knows the solution... Please help.. Thanks
Thanks for the suggestion and sorry . I only open a new topic after i saw you blast someone for piggy backing someone's topic which was not related. So is there any idea what going on....
grrrr, i got that crackling noise again tonight.
Been looking for the answer to the crackling: I'm gonna try this-plug your USB's in the USB slots farthest from screen(for laptops)
