Cstoll( http://www.virtualdj.com/homepage/cstoll/index.html ) here at VDJ forums locked this thread:
http://www.virtualdj.com/forums/98165/General_Discussion/Numark_Forum_Dies_.html
because he said the thread was "too old" and should not be reviving it.
I am telling you Cstoll, you need to verify the claims before you shut anybody down, I did check it and if the thread was old but the site was down the issue still stands and we have a right to vent our frustations with Numark.
I checked the Numark forums yesterday and took a ss which is here:
http://i901.photobucket.com/albums/ac215/takabron/numarkforum.jpg
Today you can see it for yourself, just go to the forum site here: http://forums.numark.com/index.php
You should verify the claims before you shut anyone down.
Posted Wed 10 Nov 10 @ 11:31 am
What?????????? He had a good reason to shut it down. He even explained his reason. Frustrated? Start your own thread.
Next.
Next.
Posted Wed 10 Nov 10 @ 12:46 pm
What does the availability of Numark's site have to do with Virtual DJ exactly?
Atomix only supply software to Numark under licence, if you want to have a go at Numark then contact their customer services directly.
Chris is a teamer on this site and can shut down threads as he sees fit.
Keith
Keith
Posted Wed 10 Nov 10 @ 1:19 pm
You're telling who? what?
We frequently have users drag up 3 year old threads that are no longer relevant and usually are crack users with old problems that have been fixed. So why shouldn't he close them?
You should wait till it says moderator or teamer under your name before you start chewing people out.
And yes you have the right to vent, at Numark
Topic closed
Posted Wed 10 Nov 10 @ 1:36 pm
