Topic: PLEASE HELP---CRASHES
Ok, before i lose my mind, can someone please help me...
I KEEP crashing over and over....After about 3- songs, my vd crashes..it will just stutter and stutter for about 10 seconds..then its good, but once i try to touch anything...again..here is what i have
PC LAPTOP----
PENTIUM R DUAL CORE
2,2 GHZ
64 BIT OPERATING SYSTEM
WINDOWS 7
VIRTUAL DJ PRO 7
TORQ XPONENT MIDI CONTROLLER
i havent changed any latency settings etc etc etc.....just bought this laptop..and just started to crash..thanks
Posted Mon 08 Nov 10 @ 11:39 pm
Can you try without the hardware connected and see if you get the same results.
oh also, when i close my VD then reopen, then i dont have my bpm's anymore as well.......i have to actually turn off my laptop and restart
So, it worked fine on a previous computer? Did you try a re-download of the software, and a re-install?
in the past, i had it on my desktop...i was running windows xp though..no problems..maybe its a windows 7 64 bit thing????i assume vd works with windows 7?
try reinstalling the drivers?
Does VDJ get a crash dump error, does it lockup, are you getting a Blue Screen?
thanks,
David
Make Sure Your CONTROLLER Is Updated For 64 bit
you have to isolate the problem , which is why Homeboy told you to try it with out the controller ....
