Hello......
As you can tell this is my first post to your forums but I really really wanted to stop by and give you a huge "thank you" for this awesome plug in. So thank you thank you thank you!
I started DJ'n at a private club that already had Virtual DJ a couple years ago and after being asked to do some other venues went out and purchased a pile of DMX lights. Freestlyer was a bit of a challenge to get up and running but now I have the hang of it and this plug in dropped right in.
Ur friggin' awesome!
Posted Thu 14 Apr 11 @ 2:24 pm
Yes, completely agree!! Stoked to hear you are still making improvements to this plugin SBDJ. I dont think people understand what a difference this can make to the quality of the lightshow.
Wish I could find a way to keep a freestyler cue panel open over the vdj screen though - this alt tab thing to find blackout or change cues is too much work ;)
Posted Thu 14 Apr 11 @ 2:29 pm
You won't have to worry about that soon - you will be able to control those things directly from VDJ as shortcuts - so keyboard, MIDI and skin.
Posted Fri 15 Apr 11 @ 10:34 am
That would be the final piece of the puzzle. Well done mate!
Posted Tue 19 Apr 11 @ 4:20 pm
Here is a short vid from a wedding last weekend. It is so easy now not having to change the tempo using my controller and one less piece of hardware on the table. I only have a couple of simple chases programmed in freestyler but you can see the led par cans reflecting on the back wall in perfect time to the music. This has been impossible with every sound to light software I have tried. Cant thank you enough SBDJ - surprised more djs havent been interested in this.
Posted Fri 22 Apr 11 @ 12:57 am
cheeky bloody kiwi's...LOL the vid has been blocked from us aussies :P and I wanted to see it, I still cant get my enttec open to work properly, and I was waiting for the full version of the plugin before getting a enttec pro, this may have encouraged me sooner. Sorry 'bout the quasi racism, kiwi's are awesome, that's were my girl is from.
Posted Fri 22 Apr 11 @ 4:38 am
Damn I used a song from the forties called Rum and Coca Cola by the Andrew Sisters and that seems to be why its been blocked - bizarre. Hey, happy to help if you want a hand to get it going - pm me or email dj@cheers.co.nz. I am planning to make a tutorial vid this weekend all going well. Definitely works with enttec open - I have one of those for a backup. Just hold off buying an enttec pro for a week or so - I might have a better and cheaper option.
The vid is also on my fb page - www.facebook.com/musicalcheers
Posted Fri 22 Apr 11 @ 4:49 am
That snaps to the beat nicely, very interested in you tutorial. My issue is that I cant get the driver to work on either of my pc's I have installed, uninstalled more times than I care to remember, and used any driver I can get my hands on with xp, win 7 32 and 64 bit even with the software that came with it, but still no success, I just gave up after that.
Out of interest, was the cheaper option the dmx king? I saw it on ebay a while ago, it looks good judging by the features
Posted Fri 22 Apr 11 @ 5:18 am
Hello,
need some help win7 64bit got following message if i try to install
Software already installed
Thanks for your help
Posted Fri 22 Apr 11 @ 6:10 am
Posted Fri 22 Apr 11 @ 7:18 am
Hello thanks a lot for the quick response.
I try to install the older version of virtualdj.
Thanks for the help
Thanks for the help
Posted Fri 22 Apr 11 @ 11:05 am
Here it is peeps - took a lot longer than I thought to put together - hope it helps...
Posted Sun 24 Apr 11 @ 9:07 pm
