Forum: Greek Forum
Topic: - Drop Outs Help - - Page: 4
dimitris_tsanak wrote :
Οπου realtek drivers εχεις τους αντιστοιχους δικους σου.
1) Uninstall all Realtek Drivers
2) Uninstall the High Definition Audio Controller under Device Manager > System Devices
3) Run MSCONFIG from Start Menus
4) select the boot tab
5) select advanced options
6) under max memory select 4095 (or any value under 4 GB is fine IE anything less than 1024 * 4) (εδω τρως 1mb απο την καρτα σου)
7) Restart Computer
8) Go into audio preferences and set whatever device you are using as Default (usually this will be Digital Audio (S/PDIF (High Definition Audio Device)
tha to dokimasw k auto.euxaristw poly poly
Posted Wed 17 Nov 10 @ 5:55 am
Personal Technical Assistance ..leme ...!!! lol kala to Greek Forum exei proxwrisei poly !
Posted Wed 17 Nov 10 @ 6:05 am
guys eiste respect!!!!!!
Posted Wed 17 Nov 10 @ 6:31 am
7) Restart Computer
loipon ofeilw na omologhsw oti eida trelh diafora.meta apo auto eimai internet xwris virtual konsola k eida prwth fora kitrinh grammh(mexri twra an den htan prasinh eftane kokkinh panw panw den yphrxe kapoia allh grammh)tha kanw k ta test me tin konsola gia erketes wres k tha sas enhmerwsw giati osh wra to dokimasa me konsola evgale 2 fores kokkinh grammh se fash pou epaiza me ola effe sampler ktl gia na dw oti doulevei kala (vevaia eixa pali 2 drop outs)seira exei to tsek me konsola k reuma panw.dhmhtrh thanks.oti allo gnwrizei kapoios mia pou kaname ena megalo vhma apla enhmerwnei...
Posted Wed 17 Nov 10 @ 12:33 pm
mono to laptop xwris konsola k virtual den vgazei pleon kokkines grammes (toulaxiston oxi akoma)me konsola k virtual vgazei einai kati allo pou prepei na dw?px otan paw na anoixw to virtual vgazei kapoies fores k oso paizw.auta parathrhsa mexri stigmhs
Posted Wed 17 Nov 10 @ 1:40 pm
Ok βάλτο να παίξει από την onboard soundcard .λογικά δεν θα έχεις πρόβλημα . Αν δεν έχεις πρόβλημα έχεις 3 λύσεις . Η ακολουθείς τη διαδικασία που έγραψα πάνω αλλά το βάζεις στο 3990 δεν το έχω δοκιμάσει αλλά λογικά θα δουλέψει.η θα πάρεις άλλη εξωτερική κάρτα και θα παίζεις από εκεί μέχρι να βγάλουν αλλά drivers.η τέλος που εγώ αυτό θα έκανα να βάλεις dual boot winxp pro με τα οποία και να παίζεις .μπορεί τα 7αρια να είναι σύγχρονα η κάρτα της ρελουπ δεν είναι .
Posted Wed 17 Nov 10 @ 6:41 pm
Επίσης θα δοκίμαζα το system performance στο ρελαξ ... Νομίζω ότι τα 7αρι τραβάνε τσιτες στις κάρτες και πρέπει να χαλαρώσουν λολ
Posted Wed 17 Nov 10 @ 6:49 pm
Λοιπόν στο Qosmio:
Control Panel>Hardware and Sound>Power Options
Επιλέγεις το Balanced και όχι το High Performance ή το Eco
Αν δεν βλέπεις την επιλογή "Balanced" τότε:
Δίπλα απο την επιλογή που είναι BOLD κάνεις κλικ στο βελάκι δίπλα απο εκεί που λέει Hide additional plans
Αφού κάνεις κλικ και επιλέξεις το "Balanced" τότε κάνεις κλικ ακριβώς δίπλα εκεί που λέει Change plan settings
Αγνοείς τις ρυθμίσεις που βλέπεις και πατάς στο κάτω μέρος Change advanced power settings
Θα ανοίξει ένα νέο παράθυρο. Σιγουρέψου οτι πάνω πάνω γράφει "Balanced [Active]"
Απο κάτω βάλε τις εξής ρυθμίσεις:
Toshiba Power Saver Settings>Cooling Method>Plugged in: Maximum Performance
Hard disk>Turn off hard disk after>Plugged in: 20 Minutes
Wireless Adapter Settings>Power Saving Mode>Plugged in: Maximum Performance
Sleep>Sleep after>Plugged in: 45 Minutes
Sleep>Allow hybrid sleep>Plugged in: Off
Sleep>Hibernate after>Plugged in: Never
Sleep>Allow wake timers>Plugged in: Disable
USB settings>USB selective suspend setting>Plugged in: Disabled
PCI Express>Link State Power Management>Plugged in: Moderate power savings
Processor power management>Minimum processor state>Plugged in: 5%
Processor power management>Maximum processor state>Plugged in: 100%
Display>Dim display after>Plugged in: Never
Display>Turn off display after>Plugged in: Never
Display>Display brightness>Plugged in: 100%
Display>Dimmed display brightness>Plugged in: 30%
Πατάς apply και κλείνεις τις καρτέλες.
Κάνεις επανεκκίνηση και κατά την διάρκεια του boot πατάς F2 για να μπεις στο BIOS. Πας στην καρτέλα Advanced και κοιτάς να είναι οι παρακάτω ρυθμίσεις ως εξής:
Core Multi_processing: Enabled
Dynamic CPU Frequency Mode: Dynamic
Intel Dynamic Acceleration Mode: Enabled
Σώσε τυχόν αλλαγές και βγες απο το BIOS.
Δοκίμασε τώρα (σε συνδυασμό και με την βοήθεια του Δημήτρη) να δεις τι γίνεται...
Πάντως ενημερωτικά να ξέρεις οτι οι κίτρινες κορυφές δεν είναι και τόσο σοβαρό πρόβλημα (θα πρέπει απλά να σηκώσεις λίγο το latency).
Στο Qosmio με αυτές τις ρυθμίσεις που σου έγραψα δεν έχω καταφέρει να δω έστω και μία κίτρινη γραμμή οτι κι αν κάνω... Συνέχεια είναι μέσα στα πράσινα ακόμα και με το VDJ να παίζει 2 video, Το Photoshop και το AutoCad ανοιχτό ενώ ταυτόχρονα κόβω βόλτες στο internet με Wi-Fi...
Για οποιαδήποτε άλλη βοήθεια πιστεύω οτι απο εδώ και πέρα θα μπορώ να σε βοηθήσω πιο γρήγορα, οπότε ρώτα ελεύθερα!
Posted Thu 18 Nov 10 @ 3:31 am
re paidia eiste apithanoi oloi sas...se ligo ksekinaw tis kainouries rythmiseis k sas enhmerwnw k mono gia ton kopo sas omws sas euxaristw eilikrina
Posted Thu 18 Nov 10 @ 6:01 am
auto den to vrhaka opote sou paratheto photos apo to bios k mou les an prepei na allaxw kati.ola t'alla einai ok
Posted Thu 18 Nov 10 @ 6:22 am
Αν και δεν βλέπω τις υπόλοιπες επιλογές που διαθέτει, σωστά φαίνονται...
Και μια ακόμα παρατήρηση (κάτι που διαπίστωσα στο Qosmio)
Όταν το laptop είναι idle (δηλαδή δεν κάνει τίποτα) τότε υπάρχουν περιπτώσεις που μπορεί να πάρω μια κίτρινη κορυφή ανά λεπτό περίπου στο DPC Latency checker.
Όταν όμως το laptop δουλεύει με φορτίο (π.χ με το VirtualDj ανοιχτό) τότε όλες οι γραμμές μου είναι πράσινες... Μάλιστα προσπάθησα να το ζορίσω βάζοντας και το Antivirus να κάνει full scan. Πάλι όλα πράσινα... Μόλις όμως έκλεισα τα πάντα μετά απο πολύ λίγο ξαναείδα μια κίτρινη γραμμή!
Οπότε, κάνε έλεγχο με "τυπικό" φορτίο, δηλαδή με το σύστημα σου έτσι όπως το χρησιμοποιείς συνήθως. Πιστεύω οτι θα είναι αντιπροσωπευτικότερο το αποτέλεσμα. Δυστυχώς ή ευτυχώς η τεχνολογία των i7 επεξεργαστών είναι λίγο περίεργη καθώς έχουν σχεδιαστεί για οικονομία στην κατανάλωση όπου είναι δυνατό. Έτσι πιστεύω οτι με χαμηλό φόρτο (idle) o επεξεργαστής είναι λίγο "αργόστροφος" μέχρι να σηκωθεί η χρήση της CPU και να "πάρει μπροστά" :P
Posted Thu 18 Nov 10 @ 7:20 am
mexri stigmhs paidia ola kala!!!!paizw exw msn anoikto internet k tpt.vevaia pote den ksereis.opote tha to dw arketh wra akoma.(tis prohgoumenes parathrhseis tou dhmhtrh gia tous drivers tou hxou tis afhnw opws exei?i gyrnaw opws htan?i monh grammh kokkinh pou phra htan otan to evala na kanei defragment k hmoun k sto net.an lythike alitheia tha eimai poly xaroumenh.opws k na xei ola ta ofeilw se sas k eilikrina osa thanks k na pw einai liga.
Posted Thu 18 Nov 10 @ 7:51 am
auto pou eipes na valw den tha eprepe na einai disable???na min anyshxw?oute otan to exw na paizei automix?nwris ennow otan den paizw?
Posted Thu 18 Nov 10 @ 7:53 am
Μπορείς να το βάλεις και παραπάνω αλλά ο χρόνος του idle δεν μετράει απο την κίνηση την δική σου (ποντίκι-πληκτρολόγιο). Μετράει απο την αδράνεια του δίσκου. Δοκίμασε για την ώρα με 20 λεπτά και μετά βλέπεις... Ούτως ή άλλως μιλάμε για τον δίσκο του συστήματος που σπάνια μένει idle όταν τρέχουν προγράμματα...
Posted Thu 18 Nov 10 @ 7:57 am
epishs mia allh parathrhsh.katevasa skin gia tin analysh tis othonis mou omws i kymatomorfh fainetai akoma na kanei merika travhgmatakia (poly mikra) otan paizei k oxi tipota allo skalwnw giati nomizw tha kollhsei k agxwnomai.auto pws lynetai???
Posted Thu 18 Nov 10 @ 8:01 am
apopsisdjPRO InfinitySenior staffMember since 2003
Des na min einai maximize to skin, - me maximazi mallon sou anebazei poly cpu % load (?)
Posted Thu 18 Nov 10 @ 8:30 am
afou otan einai to skin tis othonis sou den doulevei to maximize etsi den einai????
Posted Thu 18 Nov 10 @ 8:33 am
loipon twra pou perase kapoia wra arxisa pali na exw polles kokkines grammes omws paizw me anoikta internet k jdonwloader msn epithdes na dw pws paei...tha ta kleisw k vlepoume alliws kati paizei meta apo kapoia wra giati exw parathrhsei oti k xtes etsi egine.
Posted Thu 18 Nov 10 @ 8:54 am
@PhantomDeejay
gia pio antivirus milages?giati me to microsoft essentials egw exw kokkines grammes.
Posted Thu 18 Nov 10 @ 9:04 am
me tin timh auth twra i mnimi mou deixnei oti doulevei sto 51% einai kalo auto??????
Posted Thu 18 Nov 10 @ 9:11 am
36%
