deck 2 timecode_active ? deck 4 rightdeck & deck 4 select & deck 4 timecode_active : deck 4 timecode_active ? deck 2 rightdeck & deck 2 select & deck 2 timecode_active : deck 2 timecode_active & deck 2 select & deck 2 rightdeck
OK I just tried it on a few different skin and it will bring the deck infront but I still have to keep it held down and as soon as I let go it goes right back. On my skin I didnt use the LEFT/RIGHT logic does that make a difference??
Huey
Huey
Posted Mon 18 Oct 10 @ 11:29 pm
the code is for the 4 deck default skin..
and to be used in a key at keyboard or midi controller
What skin are you using? and where are you pressing down?
Posted Mon 18 Oct 10 @ 11:41 pm
OK I'm using this skin, http://www.virtualdj.com/addons/12095/Sweet_Scratch_x4.html and I have your code mapped to a button on my mixer, its an Ecler NUO4 (the 1 you told me to get, lol!!) I dont know what I'm doing wrong...........even on the keyboard it doesnt work.
Huey
Huey
Posted Mon 18 Oct 10 @ 11:45 pm
maybe i f** up .. let me test again ;) hehe
Posted Mon 18 Oct 10 @ 11:54 pm
Really got me confussed here, lol! Its not hard to do, lmao!!
Huey
Huey
Posted Mon 18 Oct 10 @ 11:56 pm
works fine here..
but if you hold the button down it will swap for as long as you hold..
I think you are just pressing the button a little bit too long..
Will try make something to avoid that side effect
Posted Tue 19 Oct 10 @ 12:12 am
Yeah thats just it, I want it to swap till I hit the button again. When I use your code I have to HOLD the button but as soon as I let go it switchs back to the other deck and that not good. That would mean I would have to hold down the button, scratch with 1 hand and not use the crossfader, lol. I wish I could find my dang charger for my camera so you could see. I'd use my phone but it just turns the config screen into a white wash.
Huey
Huey
Posted Tue 19 Oct 10 @ 12:21 am
try just tap the button quick, dont hold it at all..
Works right? (at least here)
What i mean is if you hold it too long, it will go back to deck 2..
Posted Tue 19 Oct 10 @ 12:24 am
Sorry to jump back in - this is to show whats happening...
Posted Tue 19 Oct 10 @ 12:26 am
Naw Norway it just doesnt work for me. Oh well I have a code that works and its what Schavel gave me.............
@Musicalcheers did you make a video with the other code?
Huey
Huey
Posted Tue 19 Oct 10 @ 12:33 am
ah ok, we are getting somewhere.. ;)
Looks like you have to turn OFF timecode too
does this work?
deck 2 timecode_active on ? deck 4 rightdeck & deck 4 select & deck 4 timecode_active on & deck 2 timecode_active off : deck 4 timecode_active on ? deck 2 rightdeck & deck 2 select & deck 2 timecode_active on & deck 4 timecode_active off : deck 2 timecode_active on & deck 2 select & deck 2 rightdeck
Posted Tue 19 Oct 10 @ 12:39 am
or if you dont want to make the deck you have timecode active waveform and the selected right deck, a shorter code for only swapping timecode :
deck 2 timecode_active on ? deck 4 timecode_active on & deck 2 timecode_active off : deck 2 timecode_active on & deck 4 timecode_active off
Posted Tue 19 Oct 10 @ 12:45 am
dj-in-norway wrote :
does this work?
Only turns off timecode on deck 2 but dosent turn it on deck 4.
Same thing with this 1.
Posted Tue 19 Oct 10 @ 12:50 am
hum.. lol .. its 7am here.. i probably have tired eyes ... ;)
ok what about this then?
deck 2 timecode_active on ? deck 2 timecode_active off & deck 4 timecode_active on : deck 4 timecode_active on ? deck 4 timecode_active off & deck 2 timecode_active on
Posted Tue 19 Oct 10 @ 12:53 am
I'm thinking thats the one - except the 3 should probably be a 4 - will try soon. I never knew there was a timecode_active off - thats all I needed to figure this out - haha ;)
Posted Tue 19 Oct 10 @ 12:56 am
yeah fixed the deck 3 ;) lol ... tired
Posted Tue 19 Oct 10 @ 12:57 am
Hahaa!! Thats its!! OK so why can I do the samr thing with this "deck 2 timecode_active & deck 4 timecode_active & deck 2 timecode_active"??
Huey
PS I have to be to work in 5 hours, lmao!!
Huey
Posted Tue 19 Oct 10 @ 1:00 am
OK now how do I make the wave come in front of the deck with timecode on??
Huey
You can wait till after you get some sleep if you want, lol!!
Posted Tue 19 Oct 10 @ 1:02 am
Eureka - here is what worked for me...
deck 2 timecode_active 2 on ? deck 2 timecode_active 2 off & deck 4 timecode_active 4 on : deck 2 timecode_active 2 on & deck 4 timecode_active 4 off
Thanks again for helping me thru this guys - get some sleep!! ;)
Posted Tue 19 Oct 10 @ 1:12 am
hehe ;) will add that to the script ;) but i need some breakfast now first.. lol .. will post up later ;) go sleep ;) hehe
Posted Tue 19 Oct 10 @ 1:18 am
