Got the answers I need, please disregard. Thanks
Posted Wed 27 Mar 13 @ 5:40 pm
Hi all.Please help,i have a mixtrack pro 3 and virtual dj 7.4 and got all the buttons to work but the only problem is that if i press play on the left deck then the other side play as well.Thanks in advance.
Posted Tue 11 Apr 17 @ 1:48 am
Well the Mixtrack pro 3 isn't supported in VDJ7, so you should upgrade to v8
Another issue is that you are registered as a home edition user, which doesn't work with controllers at all (except for a 10 min test period)
You should add you license information to your account. Then yuo can upgrade to v8 for free, and everything should work out of the box with the mixtrack pro 3
Posted Thu 13 Apr 17 @ 7:21 am
