Forum: Old versions
Topic: Problem BCD3000 on Vista!
Hello,
i bought a Behringer BCD3000 today, i've managed to install the driver. But still if I connect the BCD to the pc, i get the screen: Hardware needs to be installed or something, but the driver is running when the screen comes. But if I click search and install software, then I get a screen "Latest driver installed" or something like that.
When I open Virtual Dj nothing works with the BCD. I dont see the BCD on Mappers, but if I click ASIO driver, I see the BCD 3000 in that list. But then it still wont work...
Can someone help me out ?
Cheers!
Posted Sat 25 Sep 10 @ 11:28 am
Which Version of VDJ do you use ? The actual trial version should recognize ist without problems.
You need a license of Virtual DJ Professional to use this device with it.
Greets, Heiko
I got a version of a friend of mine, it didn't need a serial, it inmedietly installed 1.6.2 i think.
Cheers
You have probably been given the free DJ Console Edition that comes with the Hercules DJ Console MK1.
The DJ console itself is the key for this version and it will only work with this hardware connected. It will not work with any other hardware and is far too old to work with the BCD3000 anyway.
NOTE: VirtualDJ serial numbers cannot be shared - Doing so is a violation of the End User License Agreement: https://virtualdj.com/atomixproductions/disclaimer.html
Please download the latest trial of VirtualDJ Pro https://virtualdj.com/download/trial.html - This has support for the BCD3000.
