Hi,
Is there a list of Sound Effects which would work with the VDJ RMX Console Edition Users.
Unfortunately, Out of all the list of Sound Effects posted, very few work with the VDJ RMX Console.
Is there inbuilt limitation within the Software (Kept on Purpose), or is a general lack of support for this specific Product!
I like the Product, as it came with my Hercules Consoles, but really dissappointed with the lack of Sound effect Support!
Can somebody throw some light on this issue..
Sumedh
Sumedh
Posted Wed 15 Sep 10 @ 6:26 am
Im not 100% sure but I think you have to have the PRO edition to download all of the effects here. Look here, http://www.virtualdj.com/products/comparison.html this will show better then I can tell you.
Hope that helps
Huey
Hope that helps
Huey
Posted Wed 15 Sep 10 @ 6:53 am
Sorry, the DJ Console Edition is a free limited edition of the software and does not support custom effects and skins.
If you would like to use these and much, much more, you will need to upgrade to VirtualDJ Professional at a considerable discount: http://www.virtualdj.com/buy/index.html
Posted Wed 15 Sep 10 @ 4:32 pm
