Hello, i have the console vmx200 usb of behringer and i want to connect it to play with virtual dj but it does not do anything basically it plays only from channel 1 the 2 songs and nothing from the 2nd Channel! and the crossfader it doesnt work only high, med and low work on the first channel!
how do i connect it properly to have Deck A on channel 1 and Deck B on channel 2?
Posted Mon 13 Sep 10 @ 1:09 pm
this mixer has no midi so you can't control vdj with it. you can use it as a soundcard. check the settings in the config menu.
Posted Mon 13 Sep 10 @ 3:17 pm
Basically i searched and found a way to connect but i can not understand:\
Posted Tue 14 Sep 10 @ 2:27 pm
where you found it? maybe we can help you.
Posted Sun 19 Sep 10 @ 3:50 pm
i bought it:)
i bought it:)
Posted Tue 14 Dec 10 @ 4:14 pm
you need a 5.1 soundcard and run vdj in external mixer mode. run the green output from the soundcard to the left input on the mixer and the black output from the soundcard to the right input in the mixer. and the output from the mixer to an amplifier.
Posted Tue 14 Dec 10 @ 6:19 pm
Hi i wanna buy a dj console with the cdj 1000 mk2 and the behringer vmx 200. But i search for 1 month and i can find nothing. how to connect it to my pc? Can you guys please help me out?
Posted Mon 14 Aug 17 @ 8:38 pm
