Hi
How to use Hercules RMX with 2 sound cards?
- Input : None
- Output(s): Headphone
-Soundcard: 2 Cards - 1
- 2 Hercules RMX
i connect the headphones on hercules rmx but not work
thanks
- Input : None
- 2 Hercules RMX
thanks
Posted Fri 03 Sep 10 @ 8:14 pm
Output: Headphones + Speakers
Then under 'Soundcard', Select 'RMX CONSOLE'
Posted Sat 04 Sep 10 @ 2:27 pm
yes
but i need use like hercules steel
Posted Sun 05 Sep 10 @ 4:46 am
Pardon?
You want to to use your Rmx as the soundcard and hook up your Hercules steel?
Posted Sun 05 Sep 10 @ 2:00 pm
no
i use only rmx
- Input : None
-Soundcard: 2 Cards
Master: First card / Headphones: Second card
the second card i selected hercules rmx
but headphones not work on hercules rmx
i use only rmx
- Input : None
-Soundcard: 2 Cards
Posted Sun 05 Sep 10 @ 2:22 pm
This is my set up at the moment.
Posted Sun 05 Sep 10 @ 2:39 pm
i use this setup too
i need use like this:
http://img443.imageshack.us/img443/9886/image38720562.jpg
the headphone on RMX
Posted Sun 05 Sep 10 @ 3:11 pm
No, you don't have to. You can plug the headphones into the RMX.
On the other hand, can you tell me what version of Virtual DJ you are using and what build it is. You can find this by going to 'Set Up' and then going to 'Info'
Posted Sun 05 Sep 10 @ 3:42 pm
version 6.1
Posted Sun 05 Sep 10 @ 3:48 pm
And Build number
Example: (b***)
If you register your software, you'll get more updates, 6.1 isn't the newest. Why haven't you done this?
Example: (b***)
Posted Sun 05 Sep 10 @ 3:50 pm
b247
Posted Sun 05 Sep 10 @ 3:56 pm
Register your software, assuming its a legal version right? And then go to the downloads page and there you'll find a newer version. Download this and may help your problem.
Posted Sun 05 Sep 10 @ 4:20 pm
In the "2 soundcards" configuration, VDJ uses the 1st output pair of each soundcard.
However, since the headphone output of the Rmx is linked to Output 3/4, it will not be possible to use the headphone in this configuration.
Save yourself some trouble and just connect everything to the Rmx.
Posted Tue 07 Sep 10 @ 6:52 am
hi I was wondering how you upgrade your virtual dj software to a better version. I am currently using a hercules rmx with the version of vdj tht comes with it ive been told i can upgrade but im not sure how. Help please.
Posted Wed 10 Nov 10 @ 3:21 am
The details are on this page
https://virtualdj.com/buy/
Enter your serial number to the rebate your are entitled to.
Posted Wed 10 Nov 10 @ 6:12 am
