Forum: VirtualDJ Plugins
Topic: Gates by TexZK - Page: 2
Thanks for the New Effect.
But again, Will this effect work for the VDJ Rmx COnsole Edition?
Please don't ask the same question more than once.
Sorry, the RMX DJ Console Edition is a limited version of the software and does not support custom effects.
You can upgrade to the full VirtualDJ Professional at a considerable discount by going to http://www.virtualdj.com/buy/index.html
been looking for this effect thank you thnk you !
Can Some One Please Email Me This I Bought The Virtual Vinyl Set Used From Ebay And I Don't Have Access To Downloads Because The Serial Was Already Used On The Website So I Cant Fully Register. If Any Of You Would Be Kind To Take A Minute To Do This Would Be Gratefully Appreciated.
Email: [REMOVED]
Please And Thank You!
[Unlicensed users are not permitted to post E-mail addresses or other contact details]
If you purchased VirtualVinyl second hand then unfortunately you are not entitled to download any add-ons or updates. Once registered, software serial numbers are not transferable. Please see: http://www.virtualdj.com/wiki/Serial%20Transfer.html
Do not ask users to send you add-ons to which you are not currently entitled or your account will be locked.
If you wish to be able to download add-ons and/or future updates to the software, then you will need to purchase a brand new unused retail version of Numark Cue or the full VirtualDJ Professional direct from our website.
Realy Buy A New Set Who Would Do That When The One I Got Is Fine Just For Some Add On Realy Be Logical.
Because the one you have is second hand and as above, you are not entitled to any updates or add-on downloads. Only the original owner is entitled to these. As above, once registered the software is not transferable.
Please see the End User License Agreement (EULA): http://www.virtualdj.com/atomixproductions/disclaimer.html
However, you might still be able to use the crossgrade option if the previous owner didn't already use it - This would give you the latest full VirtualDJ Pro for $49. To check, please go to http://www.virtualdj.com/buy/index.html and enter the VirtualVinyl serial number in the box provided.
Alternatively, if the seller accepts returns, we'd recommend returning it for full refund, then either purchase VirtualVinyl brand new or a similar product such as Hercules DJTrim starter pack (This includes timecode records, sound card and VirtualDJ LE that can be upgraded to the full Pro at 50% discount.)
Thanks But Is There A Way To See If He Hasn't Already Done The 49.00 Upgrade Before I Spend The Money With No Luck? Or What About The $10.00 Premium Member Does That Work?
