I have tried everything but how do you get the right turntable to play. I can get the left to play just fine.
Posted Wed 08 Jun 05 @ 5:46 am
If you give more details we can help
Posted Wed 08 Jun 05 @ 2:53 pm
Like I said I followed all of the intructions.......I have a Myaa usb. I can get the left side to play,
no problem. When it comes to the right side I might get a pop sound or 2.
Posted Wed 08 Jun 05 @ 5:39 pm
Couple of things come to mind...sorry if some sound basic and you've already checked. The crossfader has to be in the middle on VDJ, use your external mixer to control the sound output. Check to make certain you are getting 100% or close to it on the signal from the TCV. Check the silence and gain under timecode configure and adjust. Make sure you're right turntable is grounded properly to the laptop.. If you've tried all these post again and we'll keep trying to figure it out.
Posted Wed 08 Jun 05 @ 8:44 pm
