The skin I use has very small controls for these settings and are difficult to adjust (with precision) at the venue.
It would be nice to set those (main and cue) where you want them, then have the program save those settings for the next time the program is run.
Thoughts? or does everyone just run them up full?
Posted Sat 10 Jul 10 @ 10:56 am
Not an unreasonable request. Me personally though... I run everything at full
Posted Sat 10 Jul 10 @ 11:39 am
I'm with Dizzy but I guess it boils down to what your using (exturnal mixer, or just your lappy).
Huey
Huey
Posted Sat 10 Jul 10 @ 12:51 pm
As a workaround these values can be controlled via VDJScript so you can map both level settings to one shortcut key, skin button etc.
This also allows you to profile these settings - you could have a skin panel configured with buttons mapped to a bunch of presets.
Posted Sat 10 Jul 10 @ 1:17 pm
Great idea! Never thought of mapping that. Works great. I have to do it because my sampler volume seems fixed, and if my master is at 100%, you can't hear them. I'm outputting to a mixer, and if it's at 70%, works fine.
Mission accomplished. Thanks guys!
Posted Sat 10 Jul 10 @ 6:03 pm
