i finally got the signal but i loose it, it jumps around and causes the song to go faster or slower when i hit play/pause on my pioneer cdj 800.
sometimes when i click pause it starts to go reverse any help PLEASE
Posted Fri 09 Jul 10 @ 12:50 am
You may want to start by reading this:
https://virtualdj.com/wiki/TimeCode%20Config.html
As well, enter your VDJ serial number in your profile so you'll have access to download the latest update.
Posted Fri 09 Jul 10 @ 6:09 am
what you mean update
Posted Fri 09 Jul 10 @ 10:43 pm
I had the same problem with timecoded vinyls and my mac. It seems that snow leopard and vdj 6 don't co operate well when you use timecoded vinyls or CDs. You have 3 options.
1) Install windows in you mac (with bootcamp, not virtual machine. I tried it with vmware fusion and I had problems with my soundcard.).
2) Wait until Atomix prepare the next version of VDJ (I hope the problem will be solved then).
3) Use a PC.
If I were you I would choose the 2nd and/or 3rd option. Personally, I use timecoded vinyls in my tower PC and I'm waiting the new version of VDJ to work in my mac properly.
3) Use a PC.
Posted Sat 10 Jul 10 @ 6:41 pm
In any way, register your VDJ to have access to updates, plugins etc.
Posted Sat 10 Jul 10 @ 6:42 pm
