Hey
I want to officially buy my first set of equipment for PC DJing. But I'm hesitating between the Hercules DJ Console and the Numark DJ IN A BOX v.6 (with VDJ timecoded vinyls). Can you plz tell me which one is better?
Btw,
Hercules: http://us.hercules.com/products/showpage.php?p=87&b=0&f=1
Numark: http://www.numark.com/products/product_view.php?v=overview&n=51
Thanks!
Btw,
Thanks!
Posted Fri 03 Jun 05 @ 11:25 pm
Belt drive turntables are not very adapted for DJing.
Do you really want turntables ?
You probably don't have a mixer yet.
I suggest you to get VirtualDJ full with a mixer but that's my point of view.
Posted Sat 04 Jun 05 @ 9:06 am
If you have been using vinyl before, get some decent TTs and TCV. I use a set of Stanton str8-150s and the're great for home 'workouts', At the club I use SL100s and SL-DZ 1200s..
If you're new and want a suitable interface outside a 'regular' CD player style control I'd invest in a set of XP10s
Posted Sat 04 Jun 05 @ 11:39 am
Hey clax,
why do you think a mixer is better than the Hercules DJ console?
Thanks!
Thanks!
Posted Mon 06 Jun 05 @ 5:31 am
I had a Herecules dj console and returned it. It has a latency problem. No only that its usb 1.1 not 2.0. Did not like it. I'd rather have a laptop and Virtual dj.
Good luck guy
Peace
Good luck guy
Peace
Posted Mon 06 Jun 05 @ 6:29 am
