Forum: Old versions
Topic: M-Audio Fast Track Pro Timecode ?
Hello, i was wondering if anyone could explain to me the time code setup in detail. i Tried doing it by myself but i couldn't get anything to work.
I am using a Windows XP laptop with VDJ6
M-Audio Fast Track pro Sound card
and a Pioneer CDJ-200.
Posted Sat 26 Jun 10 @ 8:58 pm
Time code use needs a multi channel card with 2 stereo inputs like the Hercules Trim 4+6, MK2, RMX u46dj or the maya 44 usb and others by user suggestion in our hardware forum.
There is much discussion on this subject in the forums here on other cards specifically.
The wiring connections are as follows:
TT or Cd deck output to the sound card input, sound card output to the mixer input, mixer output to the amp rack or powered speakers.
You will need to purchase time code vinyls or burn the cd time code from our download section.
We highly recommend you use Serato vinyls with this software.
When setting up Time Code, we suggest you follow the guide below for optimum results.
https://virtualdj.com/wiki/Timecode%20Config.html
Grounding the tables to the mixer is recommended.
