Hi guys, had a search thru here but can only find spin related stuff.
Basically im looking to see if theres a mapper for this unit, ive tried it already with the "spin" map and it doesnt work for me...
Any ideas?
Thanks
Any ideas?
Thanks
Posted Sat 26 Jun 10 @ 2:22 pm
Hello del200,
I have tested on a Mac and on Windows:
- on my Mac, in Mac OS 10.5.5, VirtualDJ 6.1 Pro + Spin (map built in VirtualDJ), everything runs OK
- on Windows XP, VirtualDJ 6.1 Pro + Spin (map built in VirtualDJ), the output channel for master and preview is just deck A + deck B, regardless of the position of the crossfader.
Posted Mon 28 Jun 10 @ 6:00 am
Typhoon have a different sysexid respect the Spin, take a look here
http://www.virtualdj.com/wiki/ControllerDefinitionMIDI.html
and write in the forum the Typhoon sysexid
For the audio setup look here
http://www.virtualdj.com/homepage/cioce/blogs/3832/_ENG__Vestax_VCI-300_Typhoon_Spin_audio_setup_on_Virtual_DJ_6.html
Posted Mon 28 Jun 10 @ 6:55 am
Hey thanks for the reply, but i cant make sense of the midi thing, do i have to make my own map? or is there one available for the typhoon, my audion set up is fine.
When i plug in the typhoon, random lights light up on the unit and i get no interface control at all
thanks again
thanks again
Posted Mon 28 Jun 10 @ 9:42 am
What Cioce wanted you do was to download and run the following application:
http://www.virtualdj.com/download/miditrace.exe
In the two boxes on the left hand side, select the Typhoon (which will probably be seen as USB Audio device)
Next , click the SEND button at the top.
This will display some numbers. Copy and post the first line (which should start with F0 7E 7F 06 ...), so Cioce (or someone else) can modify the SPIN mapping to recognize the Typhoon.
Posted Mon 28 Jun 10 @ 11:43 am
Hello Cioce,
You are right, it works in Windows XP with ASIO4ALL (I had disabled the crossfader in option menu, that is why I got only Deck A+Deck B).
Spin + VirtualDJ 6.1 Pro work
- this ASIO4ALL setting
![](/image/10634/35727/Spin_ASIO4ALL_Settings.jpg)
- this Sound Setup
![](/image/28575/35728/VDJ_Spin_Audio_settings.jpg)
- this Mapper setting (VirtualDJ 6.1 Pro defaut map for Spin).
- this Sound Setup
![](/image/22116/35729/VDJ_Spin_Map.jpg)
Posted Mon 28 Jun 10 @ 11:48 am
Hi again guys...
So i highlight both typhoon options click send and these are the results...
F0 7E 00 06 02 00 40 02 20 01 00 00 00 29 00 11 F7
B0 0C 12 00
B0 14 00 00
B0 15 57 00
B0 16 40 00
B0 17 40 00
B0 0E 37 00
B2 51 00 00
B2 52 07 00
B1 0C 00 00
B1 14 00 00
B1 17 00 00
B1 16 27 00
B1 15 3A 00
B1 0E 57 00
B2 08 5F 00
Hope this is of help!
Thanks
B0 0C 12 00
B0 14 00 00
B0 15 57 00
B0 16 40 00
B0 17 40 00
B0 0E 37 00
B2 51 00 00
B2 52 07 00
B1 0C 00 00
B1 14 00 00
B1 17 00 00
B1 16 27 00
B1 15 3A 00
B1 0E 57 00
B2 08 5F 00
Thanks
Posted Mon 28 Jun 10 @ 12:41 pm
The Vestax Typhoon support is being worked on by the manufacture. When they find that it is ready ... then we will make it available for download.
Posted Mon 28 Jun 10 @ 5:57 pm
cioce wrote :
Also note that the Typhoon as its own set of ASIO driver , so ASIO4all is not necessary
http://help.vestax.co.jp/en/detail.php?id=115&id_page_url=86&cate=0
Posted Tue 29 Jun 10 @ 6:33 am
Thanks for info Phatso, I have updated my blog.
Posted Wed 30 Jun 10 @ 5:29 am
Hi again folks thanks for replies,
Any idea on a timescale for this control being operational?
Thanks again.
Yup and to confirm the vestax asio works good thru it, even without control haha
Thanks again.
Posted Wed 30 Jun 10 @ 6:19 am
Hello again guys any update on the compatibilty of these products yet? I'm hangging out to use them publicly together
Thanks del
Thanks del
Posted Sun 04 Jul 10 @ 8:47 am
As I stated above:
Posted Sun 04 Jul 10 @ 9:11 am
guyz can u help me ,how to used my vestax typhoon on vdj,tnx guyz
Posted Mon 12 Jul 10 @ 10:17 am
Hi
I know its being worked on and i know its been said but any idea when if at all this will be ready
Posted Sat 17 Jul 10 @ 3:15 pm
Hello
I get the just not down with the mapping itself, can someone write one for the Typhoon?
it goes with VDJ 6 ... it only lights up the cue button nothing else.
With the tractor makes the mix for me no fun ... I find virtual dj every time better!
thank you
thank you
Posted Mon 19 Jul 10 @ 10:32 am
Im glad to hear that I'm not the only who thinks the Virtual DJ is a better choice thank Traktor.....
I just bought my Vestax Typhoon 3 days ago, and already Im looking for a better solution. Lucky for me I had a friend show me the difference that the Virtual DJ software made on his Ion Discover DJ, and I'm sold.
So I sit here asking the same question that seems to be on a lot of peoples minds.
1. Does Virtual DJ support the Vestax Typhoon unit?
2. Are my only options to buy the Pro version?
3. Does the demo version also support the Vestax Typhoon, so that I can give it a whirl before spending some cash?
Thanks in advance to anyone that can help,
DJ NoNameYet
DJ NoNameYet
Posted Fri 30 Jul 10 @ 5:21 pm
1. The Vestax Typhoon is not supported yet, but should be soon.
2. VirtualDJ Pro is required to use MIDI controllers.
3. A future version of the demo will support the Typhoon, once support has been added.
Posted Mon 02 Aug 10 @ 12:06 pm
Please make this quick ! I canĀ“t wait to use my typhoon with VDJ. :-)
Posted Mon 09 Aug 10 @ 4:04 pm
Good day to all. Can somebody in here help me. I have a Vestax Typhoon and I manage to map my machine in VDJ. My problem is when I start VDJ and begin to use the machine some buttons lights up automatically. Can somebody help me with this?
Posted Tue 10 Aug 10 @ 5:15 pm
