Hey guys,
Quick question - when I updated to the newest version of VDJ something odd has happened. In vinyl mode for my 3700s when I hit play there is a long delay. Sounds like a break effect is on (but it's not). It sounds like the song is 'getting up to speed.'
When I turn vinyl mode off and use the 3700s in CD mode I can cue and hit play with no delay and no issues. This is probably a simple fix, but I'm not finding it. Any suggestions?
Thanks
Thanks
Posted Mon 14 Jun 10 @ 8:10 am
Same problem here i reported on another forum, let me know if you find the answer
Posted Mon 14 Jun 10 @ 10:24 am
Any suggestions here to help fix the problem? Still haven't been able to figure this out and I am having to run my decks in CD mode so that I can mix properly. Very frustrating!
Posted Tue 15 Jun 10 @ 7:33 am
Hey Brother all you have to do is turn off the platter, the right button next to the platter change it from red to green.. easy fix!
Posted Sun 27 Jun 10 @ 10:47 pm
I have 6.0.5 all the other version did the same thing that's happening to you. I have no problems at all hope that helps
Posted Mon 28 Jun 10 @ 11:42 pm
